SCSI on PowerMac G4 3,3
    AvatharV
    Posts: 15 from 2012/11/20
    I am working out some installation issues at the moment, but in testing hard drives for possible use as boot drives, I have come across some of my old Amiga drives.
    I know I have a bunch of old SCSI drives. Is SCSI supported in MorphOS? If so, does anyone have any recommendations on what which specific card to get?
    I have a SCSI tower with 3 hard drives, a CD Rom, and a ZIP drive. I would love to be able to find out what was on them.
    -AV
    Powerbook G4 1.67Ghz, 2G RAM, 110GB HD, MorphOS 3.10
    Mac Mini G4, 1 G RAM, MorphOS 3.8
    PowerMac G5, 1.8G, 4G RAM, MorphOS 3.10 (one day)
  • »22.11.12 - 03:45
    zukow
    Posts: 650 from 2005/2/9
    i have symbios 810 here and it works without serious problems (from time to time it throws errorlog to morhos debuglog during booting).
    Morphos creates symbios.device in memory. I haven't tested drives but scanners work ok (i'm the author of http://library.morph.zone/Scanning_with_SCANdal)
  • »22.11.12 - 05:50
    Posts: 12498 from 2003/5/22
    http://www.morphos-team.net/hardware has a list of supported SCSI host adapters.
  • »22.11.12 - 09:25
    Andreas_Wolf wrote:,
    But aren't there some problems with using SCSI on Mac G4 computers running MorphOS3.1? I thought I read that those SCSI controllers listed only worked on the Pegasos1&2 computers, and not the G4 PowerMac's?
    I would like to have a SCSI2, or SCSI3 controller on PCI card that works with MorphOS3.1 and my G4 PowerMac (and soon G5 PowerMac), but don't know which one('s) will work, if any.
  • »22.11.12 - 17:37
    Simon
    Posts: 809 from 2008/7/6
    That is solved since that latest update. I have a Tekram DC-390u in mine and i recognized my external Zip without problems.
  • »22.11.12 - 18:28
    zukow
    scsi cards work with powermacs since 3.0
  • »22.11.12 - 19:46
    I have used them, but since most of my drives are u320 I find the controllers a bottleneck.
    So the SCSI drives are either sitting unused or they're in PCs.
    And 10K rpm drives are noisy buggers.
    As a scanner interface, I can understand SCSI.
    But SATA is the way to go for hard drives.
    [ Edited by Jim 22.11.2012 - 22:00 ]
  • »22.11.12 - 19:58
    True. And just for reference the relevant quote from the 3.0 release notes:
    "Fixed Symbios SCSI cards support on PowerMacs."
  • »22.11.12 - 21:13
    Great! I obviously did not read the release notes for 3.0, or 3.1. In fact, I rarely read the release notes for any new version of MorphOS too closely, but I should.
  • »22.11.12 - 22:23
    AvatharV
    Okay, this is all very helpful. Any recommendations on where to pick one up, these days?
    Back in the day, I used to do a lot of my Amiga purchases on eBay. Still a good way to go, or are there better options?
    I live in California near San Francisco.
    -AV
  • »23.11.12 - 00:12
    Not that I know of.
    That's where you're going to find the best deal.
  • »23.11.12 - 04:35
