Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Hardware
MorphOS not booting on a PowerMac G4
Zergei72
# 1
Just looking around
Posts: 6 from 2012/11/17
Ok ...
got a quicksilver 2002,
733Mhz, 768MB RAM
DIGI001 - pci card installed .
I can't boot from the MorphOS-CD .
Quark / Openfirmware console failed .
System : (PowerMac3,5) Rev <>
CPU0: <PPC7450> Version 0x0000 Revision 0x200
CPU0: CPUClock 733333331 BUSClock 133160004
THAT is all I get when I try to boot off the cd .
tried two brands of CD/DVD-drives .
dunno 'bout the Graphics-board .
Please,
help me out !!!
17.11.12
07:01
analogkid
# 2
Posts: 719 from 2004/11/3
I think you should check out whether you have an ATI or NVidia gfx-board installed.
17.11.12
07:17
Moderator
Posts: 2564 from 2003/2/24
There is no QuickSilver2002 with 733MHz, what does exist is a 2001 model:
http://www.everymac.com/systems/apple/powermac_g4/specs/powermac_g4_733_qs.html
This one came with a GeForce2 as standard GFX-card (not supported).
I got a spare Radeon7000 and 9000pro (both Mac-editions) but depending on your location it might be more sensible to look out for one on ebay or suchlike.
17.11.12
08:20
Zergei72
# 4
Just looking around
ok ... got myself a box of display adapters from my neighbor ; (:
problem is they're all pc versions ;
how can I make them mac compatible, how do I flash the rom ?
for all I've gots this PowerMac G4 and a Intel Macbook .
20.11.12
18:13
