Help needed with SSD hard drive!
    Posts: 12558 from 2003/5/22
    > On MorphOS an SSD will increase boot time
  • »16.11.12 - 10:58
    SoundSquare
    Posts: 1214 from 2004/12/1
    MorphOS for sure gets hell fast and recent SSDs are putting the internal IDE to its limit, so even a cheap SSD will boost the PB to its limit.
    sure but a cheap SSD won't be as reliable as an OWC for example, it depends how long you want to use it and how much you care for your data...
  • »16.11.12 - 12:54
