PCI USB 2.0 card in PowerMac
    Motosampy
    Posts: 199 from 2004/8/14
    I just noticed that if I install a PCI USB 2.0 card (VIA chipset) into my FW800 MorphOS loses the onboard USB 1.1 ports
    Can anyone confirm this ?
  • »03.11.12 - 17:35
    pampers
    Posts: 1068 from 2009/2/26
    I can't. My onboard ports works fine with my USB PCI card..
    MorphOS 3.x
  • »03.11.12 - 17:40
    Doffo
    Posts: 508 from 2010/10/14
    Heard someone else having that issue... Mine works great, but I have a NEC chipset USB. Believe it's a Belkin card.
    YUUUP!
  • »03.11.12 - 17:42
    Posts: 1090 from 2004/9/23
    I just ran into the same problem with my powermac 3,4 after inserting an USB card.
    Onboard somehow failed completely. My solution was to delete envarc:sys/Poseidon.prefs and reboot.
    Since then all problems are gone.
    Geit
  • »03.11.12 - 18:02
    zukow
    Posts: 655 from 2005/2/9
    check poseidon prefs but afaik all FW800 has onboard USB 2.0 and morphos since 3.0 knows that it is usb2.0
  • »03.11.12 - 18:28
    Motosampy
    Thanks geit, deleting the prefs helped here too.
    And you are right zukow, onboard is 2.0 (the keyboard hub is 1.1)
  • »03.11.12 - 20:12
    pan1k
    Posts: 147 from 2009/1/20
    I lose a single port. I will try to delete the prefs also.
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »06.11.12 - 13:46
