morphos.key not working [Solved]
    catohagen
    Posts: 297 from 2003/5/20
    So I have 2 mac-mini's with morphos.key for both, the second mini have wifi built in, so i wanted to use that as my main system, so i swap the harddrives and copied the correct keyfile to devs: but morphos starts up in demo mode, do i need to get new keyfiles for both systems ?
    [ Edited by hooligan 01.11.2012 - 07:18 ]
  • »31.10.12 - 14:49
    Posts: 2553 from 2003/2/24
    you obviously did NOT copy the correct keyfile ....
    If your mini was registered with a keyfile before it will again be registered with another HD and that same keyfile.
    Only exchange of mobo would require a new key.
  • »31.10.12 - 14:55
    catohagen
    Booted the second mini now, replaced the keyfile, booted and its registered on my name, so atleast one keyfile works...Im pretty sure i have copied the right one on the other mini aswell
  • »31.10.12 - 15:06
    catohagen
    oh fuck, typo, renamed keyfile was morhpos.key, nevermind works now :-D
  • »31.10.12 - 15:21
