Is there something strange with my PB or am I wrong?
    Miky060
    Posts: 694 from 2003/2/24
    I am starting to fear that my Powerbook 5,8 (1,67Ghz 2 GB of DDR2) goes slower than how it should go.
    I hear of people that play 720p movies smoothly and that have excellent responsiveness of all the system, while here even moving/resizing windows is totally far from smooth, so I did some test to have a comparsion and got different results from what I read here (see PowerBook G5 1,67GHz):
    http://amiga-news.de/en/news/AN-2012-02-00011-EN.html
    In the LAME TEST my same machine takes just 15s to complete the conversion, while mine took 19s:
    MorphOS:> lame DOWNLOAD:AKsack.wav
    LAME 3.98.4 32bits (http://www.mp3dev.org/)
    Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
    Encoding DOWNLOAD:AKsack.wav to DOWNLOAD:AKsack.wav.mp3
    Encoding as 44.1 kHz j-stereo MPEG-1 Layer III (11x) 128 kbps qval=3
    Frame | CPU time/estim | REAL time/estim | play/CPU | ETA
    10529/10529 (100%)| 0:18/ 0:18| 0:19/ 0:19| 14.607x| 0:00
    kbps MS % long switch short %
    128.0 100.0 76.1 13.4 10.5
    Writing LAME Tag...done
    ReplayGain: +0.5dB
    In the MPLAYER TEST my same machine takes just 69,8s. Here are my results:
    MorphOS:> mplayer -benchmark -nosound -ao null -lavdopts skiploopfilter=none "DOWNLOAD:Prometheus - Trailer.mp4"
    Port "MPLAYER.1" already exists!
    MPlayer SVN-r34869-4.4.4 (C) 2000-2012 MPlayer Team
    192 audio & 399 video codecs
    Playing DOWNLOAD:Prometheus - Trailer.mp4.
    libavformat version 54.3.100 (internal)
    libavformat file format detected.
    [h264 @ 0x2c4f7c08]Warning: not compiled with thread support, using thread emulation
    [aac @ 0x2c4f7c08]Warning: not compiled with thread support, using thread emulation
    [lavf] stream 0: video (h264), -vid 0
    [lavf] stream 1: audio (aac), -aid 0, -alang eng
    VIDEO: [H264] 1920x816 24bpp 90000.000 fps 6828.3 kbps (833.5 kbyte/s)
    Clip info:
    major_brand: mp42
    minor_version: 0
    compatible_brands: mp42isomavc1
    creation_time: 2011-12-23 08:24:51
    genre: Trailer
    artist: 20th Fox
    title: Prometheus - Trailer
    encoder: HandBrake 4344svn 2011111001
    date: 2012
    Load subtitles in DOWNLOAD:
    VO: [cgx_overlay_gui] Hello!
    VO: [cgx_overlay] Hello!
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    libavcodec version 54.14.101 (internal)
    Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
    Audio: no sound
    Starting playback...
    Unsupported PixelFormat 61
    Unsupported PixelFormat 53
    Unsupported PixelFormat 81
    Movie-Aspect is 2.35:1 - prescaling to correct movie aspect.
    VO: [cgx_overlay] 1920x816 => 1920x816 Planar YV12
    VO: [cgx_overlay] Window mode.
    VO: [cgx_overlay] : window size: 1432x612.
    VO: Disabling blanker
    VO: [cgx_overlay] : cgxvideo.library >= 43.6 detected, using doublebuffer
    VO: [cgx_overlay] : using draw_slice_420p (PLANAR) primitive
    BENCHMARKs: VC: 94.068s VO: 25.035s A: 0.000s Sys: 1.534s = 120.636s
    BENCHMARK%: VC: 77.9763% VO: 20.7522% A: 0.0000% Sys: 1.2714% = 100.0000%
    VO: Enabling blanker
    Exiting... (End of file)
    What's wrong with my machine? :-(
  • »25.10.12 - 18:33
    Posts: 1099 from 2004/9/23
    Just perform the test in RAM:. Harddrive is slow and fragmented.
    The reason you cannot play 720p is that it depends on the used codec, bitrate and so on, too.
    Geit
  • »25.10.12 - 19:13
    Miky060
    I performed again the test from ram: and nothing changed.
    After than I performed the tests booting from MorphOS CD and got a bit of improvement. Lame result is 16/17 s while mplayer test results are:
    BENCHMARKs: VC: 88.068s VO: 25.035s A: 0.000s Sys: 1.534s = 112.000s
    Can some MOS developer explain this behaviour and why there so big difference with the test results in the linked page (probable performed buy some developer before 3.x was out) Can the graphic drivers difference (internal beta VS public version) interfere with the test results ins some way?
  • »27.10.12 - 07:44
    You also need the very same lame version supporting altivec. Just using a different version can give other results.
    Also check the performance settings as you powerbook may be configured to run slower when battery powered.
    Its quite imposssible your system got slow due some hardware failure.
    Geit
  • »27.10.12 - 08:28
    pampers
    Posts: 1071 from 2009/2/26
    Did you install any 3rd party software recently? Meaby your machine is overheating?
    MorphOS 3.x
  • »27.10.12 - 08:54
    Miky060
    It's not overheating and the software installed is the same I use since years.
    The fact is that even booing from a clean MorphOS installation (MorphOS CD) the results are worse than the one in the link.
    @ geit
    I did the tests with AC supply fitted. About the hardware failure I was thinking to the ram. I have 2x1GB modules and I remember something about morphos having problems with more than 1,5GB of Ram. Moreover if I do memtest it gives everytime different values, much different. Isn't this strange?
  • »27.10.12 - 09:17
    Miky060
    Another thing: the lame version is the last one with altivec support
  • »27.10.12 - 09:40
    Posts: 12565 from 2003/5/22
    I think you've misunderstood something. It's true that MorphOS can't use more than 1.5 GiB RAM but more physical RAM installed doesn't hurt as anything above that 1.5 GiB barrier is simply ignored basically.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8756&forum=3&start=1
  • »27.10.12 - 12:11
    Posts: 2220 from 2003/2/24
    Miky060,
    But what do you have in Laptop settings in MorphOS Preferences for AC power profile? Checkmark in "Adjust CPU frequency..." or not? There should be checkmark to get full speed.
  • »27.10.12 - 16:54
    boot_wb
    Posts: 874 from 2007/4/9
    Hi Miky060,
    A few things spring to mind:
    1) Anything running in the background (eg OWB?)
    2) Anything starting from wbstartup when booting from hdd?
    3) Are both your source and destination set to ram: for the lame test?
    4) You missed the "-vo null" option from your mplayer command compared to Piru's benchmark comparison.
    New Shell process 6
    Ram Disk:> rich:downloads
    Rich:Downloads> copy "prometheus - trailer.mp4" ram:
    Rich:Downloads> copy "aksack.wav" ram:
    Rich:Downloads> ram:
    With Powerbook 5,6 (1,67GHz; 1GB DDR Ram; 128MB VRam) I get:
    Lame test:
    Ram Disk:> lame aksack.wav
    Encoding aksack.wav to aksack.wav.mp3
    10529/10529 (100%)| 0:16/ 0:16| 0:17/ 0:17| 16.822x| 0:00
    ReplayGain: +0.5dB
    MPlayer test:
    Ram Disk:> a:mplayer/mplayer -benchmark -nosound -ao null -vo null -lavdopts skiploopfilter=none "prometheus - trailer.mp4"
    Playing prometheus - trailer.mp4.
    [h264 @ 0x2fdd9948]Warning: not compiled with thread support, using thread emulation
    [aac @ 0x2fdd9948]Warning: not compiled with thread support, using thread emulation
    Clip info:
    major_brand: mp42
    minor_version: 0
    genre: Trailer
    artist: 20th Fox
    date: 2012
    Load subtitles in Ram Disk:
    Audio: no sound
    VO: [null] 1920x816 => 1920x816 Planar YV12
    BENCHMARKs: VC: 83.663s VO: 0.010s A: 0.000s Sys: 0.557s = 84.230s
    BENCHMARK%: VC: 99.3275% VO: 0.0114% A: 0.0000% Sys: 0.6611% = 100.0000%
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »27.10.12 - 17:06
    Miky060
    @boot_wb
    You're right, I missed -vo null parameter!! Now the mplayer test gives much better results:
    BENCHMARKs: VC: 93.817s VO: 0.011s A: 0.000s Sys: 0.732s = 94.559s
    BENCHMARK%: VC: 99.2151% VO: 0.0111% A: 0.0000% Sys: 0.7738% = 100.0000%
    Now I want to try it again booting from MOS CD so I am sure nothing can interfere. About the tools I launch at boot I have these apps in my WBstartup drawer:
    - Mixer
    - Clonck
    - MMKeyboard
    - Poly_Net
    About lame test both source and destination are Ram disk.
    In every case both mine and your test are still far from Piru's ones. How can this be possible?
  • »28.10.12 - 06:57
    Miky060
    Ok, booting from MorphOS CD I get these results:
    LAME TEST
    10529/10529 (100%)| 0:16/ 0:16| 0:16/ 0:16| 16.863x| 0:00
    MPLAYER TEST
    BENCHMARKs: VC: 87.966s VO: 0.010s A: 0.000s Sys: 0.634s = 88.610s
    BENCHMARK%: VC: 99.2728% VO: 0.0112% A: 0.0000% Sys: 0.7160% = 100.0000%
  • »28.10.12 - 07:18
    boot_wb
    @Miky060
    I get a bit of variance when I run the benchmarks - sometimes 16s, sometimes 17s for the lame test.
    Best results were gained when freshly booted, nothing running in the background, and only aksack.wav in ramdisk.
    It's a shame the precision is to 0 decimal places, as Piru's result could be 15.99s whilst mine could be 16.01 seconds.
    Strange that your mplayer result is greater - could be that the DDR/DDR2 makes a difference I suppose (DDR having lowe latency)... would be useful to know if Piru's benchmark was run on a 5,6 or a 5,8.
    I wouldn't call 82.2s (Piru's) and 83.6s (Mine) a huge variance though - less than 2% difference.
    (PS Just re-ran the mplayer test twice more and and got VC: 84.020 and VC: 83.533, so there is definitely a bit of variation when running the tests.)
    EDIT - Also a:mplayer/readme.morphos says:
    This is a build of MPlayer 1.0-SVN-r34869 (18.04.2012).
    whilst the benchmark thread links to:
    MPlayer 1.0-SVN-r33557 (04.06.2011)
    which could also make a difference.
    [ Edited by boot_wb 28.10.2012 - 10:17 ]
  • »28.10.12 - 08:09
    Miky060
    boot_wb you're right, I looked again at Piru's results and there is not big difference now. I confused AmigaOne X1000 results (69,8s) with PowerBook results (82,2s) in the mplayer test so I believed that the Piru PB took only 69s!
    P.S. Your 5,6 seems really fast. It should be interesting to understand if Apple choice to adopt DDR2 in the last PowerBook models actually improved battery life.
  • »28.10.12 - 10:24
