Powerbook hdd activity light
    caver99
    Posts: 131 from 2012/6/14
    is it possible to either mod the hardware or is it software controlled, the led on the front of the powerbook so when there is any hdd access the light flashs?
    Powermac quicksilver Dual 1ghz Dual Boot Morph OS 3.7 and OS X 10.5.8
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »15.10.12 - 17:04
    pan1k
    Posts: 147 from 2009/1/20
    Maybe someone can write a module like the battery module?
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »15.10.12 - 18:21
    pampers
    Posts: 1071 from 2009/2/26
    But there is one already called drivelamp.
    MorphOS 3.x
  • »15.10.12 - 18:39
    caver99
    is this on the os or for the led on the from of the PowerBook?
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »15.10.12 - 19:17
    Posts: 12558 from 2003/5/22
    Drivelamps.sbar comes with MorphOS and can visualize (on my Mac mini) accesses for ide.device, idemacio.device and usbscsi.device.
  • »15.10.12 - 19:32
    caver99
    Ah right, i was wondering if there was a hardware mod to make the led on the lid catch become a hdd led.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »16.10.12 - 04:13
    Posts: 1095 from 2004/9/23
    caver99,
    As the internal harddrive is IDE, you for sure could apply an LED or replace the power LED by a dual LED and simply adding a transistor and a resistor to fire it up on ide transfers, but I guess that will be overkill and more or less result in a damaged powerbook for the most people around.
    Geit
  • »16.10.12 - 06:13
    caver99
    never thought of replacing it with a dual led, will have to see if i can find one the right colour and a red/blue as the second, i remember adding the led mod back in the day to the xbox for the mod chips to one of the pins with a resistor.
    Thanks will look into something and possibly post some pics.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »16.10.12 - 06:50
    caver99
    would anyone happen to know what the size is of the led on the lid catch?
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »16.10.12 - 08:38
    caver99
    i have dug out a spare from a knackered powerbook but the little board says 94v on it, surly the led cant be 94v or is this correct?
    might have to lift the lid on my pb and use a volt meter to check
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »17.10.12 - 05:35
    Fraggle
    Posts: 203 from 2012/9/2
    Can you show us a picture?
    Fraggle
  • »17.10.12 - 08:15
    caver99
    i have a tri colour led to try and see if i can get the ide to flash it.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »17.10.12 - 11:52
    Posts: 3336 from 2003/3/5
    The led is software controlled so in theory we could make it blink on hdd activity. There will probably be some userland interface to control the led state at some point, so some brave soul might adjust it to blink on hdd activity.
  • »17.10.12 - 12:05
    caver99
    i am going to attempt to make it flash as the hard drive is accessed via the hardware side, as if a program loads and takes over the screen i can see if it accessing the drive or just crashed.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »17.10.12 - 14:16
    Fraggle
    Well sight unseen, it is highly unlikely to be anything other than a standard LED with about 1.5V drop so just connect it to the correct IDE pin with a resistor to limit the current.
    You may need to use a pass transistor dependent on the LED but it`s still very simple.
    Good idea and good luck - I may duplicate your hack.
    Fraggle
  • »17.10.12 - 16:37
    caver99
    As a test i used a 3mm round led and shaved it to fit in the slot made the green part connect to the original connector and put the red leg to pin 39 of the ide connector and it works well all i need to do now is get an smd tri colour led to fit the board and fix the ide wire to it.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »17.10.12 - 18:42
    Posts: 2094 from 2003/6/4
    If there place for 3x3 mm² smd led I may point you to the Nichia NSSM065T - a high quality RGB SMD LED.
    Draws up to 50 mV (red) or 35mV(green/blue) and costs about 1-2 EUR in single qantity.
    [ Editiert durch Zylesea 17.10.2012 - 22:39 ]
  • »17.10.12 - 19:35
