Large harddrive support in Powermac?
    pan1k
    Posts: 147 from 2009/1/20
    Can I put in a 1TB or 500GB Drive in my Powermac, and will it be supported under MorphOS?
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »15.10.12 - 14:21
    hooligan
    Posts: 1948 from 2003/2/23
    You forgot to name your topic (it shows as blank and people cant read it). I fixed it but edit your posts topic if you want to change it.
    - Hool
  • »15.10.12 - 14:38
    Posts: 2220 from 2003/2/24
    pan1k,
    Yes you can, but remember that each filesystem has its own limits for partition sizes. For example, keep SFS partitions under 128GB each. Find out the limits and features, and then select suitable filesystems for your needs.
  • »15.10.12 - 14:51
    pan1k
    If I make an HFS partition, that's going to be read-only under MorphOS right? I'm trying to downsize my physical media and rip my DVDs and CDs, and store them long term. I know SFS is limited to 128GB.
  • »15.10.12 - 14:57
    Posts: 12558 from 2003/5/22
    HFS is read/write, HFS+ is read-only.
  • »15.10.12 - 15:19
    pan1k
    Thanks for clearing that up. So I plan to have my 160GB drive for MorphOS Apps / Games / UAE Stuff and a large External RAID for my Media.  8-)
  • »15.10.12 - 15:41
