Pegasos II Won't Boot..
    pan1k
    Posts: 147 from 2009/1/20
    All of a sudden, my Pegasos II won't boot. I get no video output. The LED's in the case are on. I reseated the CPU card and RAM. Could it be a bad battery?
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »19.09.12 - 00:56
    imax
    Posts: 41 from 2004/9/20
    My be battery.
    Try replacing the memory and video at the exact working.
  • »19.09.12 - 02:51
    Posts: 1521 from 2003/2/24
    You could try serial cable to see firmware output.
  • »19.09.12 - 03:18
    Posts: 1372 from 2010/1/6
    I had the same problem some time ago - in my case the CPU-card has to be reworked ..... Do you have a another card to test?
  • »19.09.12 - 05:29
    zzd10h
    Posts: 20 from 2012/1/10
    I had, too, the same problem on my Peg2 after 1 week without switch-on it.
    i just changed the motherboard battery and it was OK.
    Hoping for you that it's just that.
  • »19.09.12 - 20:52
    CountRaven
    Posts: 566 from 2007/12/10
    Same symptoms as mine....
    I had to go the hard way as it was not the battery...
    My cpu and board are on their way to be fixed... but no one knows the final result.
    I wish you all the best...
    [ Edited by CountRaven 19.09.2012 - 23:01 ]
  • »19.09.12 - 20:59
