Morphos and SATA drives
  • fmh
    fmh
    Posts: 75 from 2012/8/23
    I just installed Morphos on my old G4-500DP Mac. I'm having some issues with that machine and no sound. I have a newer G4-800DP Mac but I have Sonnet SATA controller in it. I believe the controller makes the Mac think it is a SCSI drive. Short of me attempting an install does anyone know if this will work or would I have to install Morphos on an ATA drive?
    G5 2.0DP, MorphOS3.13
  • »09.09.12 - 12:22
    Posts: 2553 from 2003/2/24
    The Sonnet should be Sil3112 based which is supported with MorphOS3.x.
    The only other user with such a card I know of seems to have some minor problems while my unflashed PC card works flawless (but I have to use a CF-card on the IDE bus for the boot: partition).
    Short:
    Bootb the CD and see if MorphOS sees the SATA-HD.
  • »09.09.12 - 13:35
    fmh,
    As Kronos pointed out, you're going to need an IDE boot partition.
    But a simple CF or SD to IDE adapter could handle that.
    I too have an unflashed PC SATA card and it works perfectly.
  • »09.09.12 - 14:05
    @Jim
    He has a Sonnet (AKA Mac-compatible SATA-card) so there should be no need for an extra boot-drive.
    I have no idea wether Sonnet offered SATA-cards with other chipsets but my QS came with a nameless Mac-SATA+ATA133 card that is not supported under MorphOS.
    So again:
    Boot the CD and see if MorphOS sees the SATA-HD.
  • »09.09.12 - 14:51
    You're right.
    I didn't think about that.
    I only have Sonnet card I have is a Tempo SATA X4P, which I don't think is supported (and can't be booted from anyway).
    Sory Kronos.
  • »09.09.12 - 15:23
