Tested scsi controllers in my powermac
    Simon
    Posts: 809 from 2008/7/6
    I tested these 2 controllers in my digital audio powermac:
    Tekram Ultra 2 Scsi DC-390U2W
    Tekram PCI to Fast SCSI DC390U
    Might be usefull info for someone ?
  • »29.07.12 - 12:52
    Posts: 12558 from 2003/5/22
    Maybe if you add the outcome of your tests? :-)
  • »29.07.12 - 23:13
    Simon
    I knew I should have added " successfully " between "I" and "tested" ...
  • »30.07.12 - 04:09
    Thanks.
    I've got a few spare Ultra320 drives lying around that should be backwards compatible.
    Then again, I've already got an SATA controller, so this might be a downgrade.
  • »30.07.12 - 12:28
    Simon
    I use it for to connect an old Plextor scsi cdwriter. Still the best one for writing PS1 backups that you want to use in a real Playstation 1.
  • »30.07.12 - 12:51
