I know this is not MorphOS related, but thought that some of you might be familiar with CPU upgrades and heat problems of overclocking.
I have not overclocked anything, but I did just do a CPU upgrade on my 1.66GHz Core Duo Intel powered MacMini to a 2.33GHz Core2Duo CPU.
I used Arctic Silver thermal transfer paste (the good stuff) and I was able to do the CPU upgrade without removing the Heatsink sensor, so I am sure it is still working correctly, but my question is about the heat readings that I am now seeing using the "iStat" widget.
Right now as I type this message with only Firefox running on my MacMini, I am seeing an average CPU temp of 80 degrees Celsius, while the Heatsink is only 54 degrees Celsius.
I have seen the CPU temperature rise to 100 degrees Celsius and that seems way too high, so I am wondering if my Heatsink needs to be removed and the Arctic Silver needs to be re-applied? I broke one of the plastic pins with springs and barbs that attaches the Heatsink to the motherboard and holds it against the CPU, but I replaced it with a bolt that fit well.
It just seems that the heat difference is too much between the Heatsink and the CPU readings that iStat is showing me, and also that my CPU should not be getting that hot.
I have not experienced any lockups while running MacOSX 10.6.8 Snow Leopard, but I am worried that there might be something wrong with the CPU upgrade and don't want to burn up the MacMini and damage anything.
Anyone have any ideas, or comments?
