Batterylevel of Powerbook
    amiga4001
    Posts: 454 from 2006/11/16
    There seems to be a way to display the batterylevel of a powerbook with the help of sbar?
    Where can I find the sbar settings?And how to change?
    Sorry if been asked already
  • »26.06.12 - 19:37
    Posts: 3279 from 2003/3/5
    Right click on the screen depth gadget (right-top edge of screen), select Settings->Title, add %rb to the strings.
  • »26.06.12 - 21:26
    boot_wb
    Posts: 874 from 2007/4/9
    @Jacadcaps - thanks for the tip.
    Do you know if MorphOS 3.0 currently provides the Batterylow notification for Magicbeacon?
    I just can't seem to get it configured for the battery notifications at any threshold, and am not sure if I'm wasting my time trying with the current release. :)
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »28.06.12 - 17:48
    pampers
    Posts: 1061 from 2009/2/26
    Sorry but i'm too lazy to translate it propely: http://translate.google.pl/translate?sl=pl&tl=en&js=n&prev=_t&hl=pl&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fmorphos.pl%2F2717
    MorphOS 3.x
  • »28.06.12 - 18:54
    boot_wb
    Thanks Pampers & JacadCaps.
    That's exactly what I needed :-)
    Would still be good to get MagicBeacon configured though.
  • »29.06.12 - 07:29
    amiga4001
    thanks for the guide.
    Also installed the new battery bar...energy which shows a percentage of remaining batterypower great.
  • »29.06.12 - 17:50
    FerruleMedia
    Posts: 20 from 2012/6/15
    Where is the Energy.sbar file supposed to be placed? Sorry if this is a stupid question, but i'm new to MorphOS and there was no installguide :)
  • »29.06.12 - 18:12
    Copy it to SYS:Classes/Screenbar then right click on the screen depth gadget and hit 'Rescan'.
  • »29.06.12 - 18:34
    Posts: 1077 from 2004/9/23
    Grunch also provides a packet for the energy.sbar and takes care about the installation and runtime list update.
    Http://grunch.geit.de
    Geit
  • »29.06.12 - 21:13
    stephen_robinson
    Posts: 746 from 2007/4/22
    The Energy sbar module is excellent piece of work BTW.
    Many tanks!
  • »30.06.12 - 15:43
    dake
    Posts: 204 from 2007/9/14
    Thanks jacadcaps for the excellent Energy sbar.
    This is a big help to trim the system for a longer battery time.
    However the Drain/Charge Current diagram is increasing with the decreasing Voltage. Is it possible to get this in Wattage instead? You just do a small calculation, Voltage * Amperage = Wattage.
    The way it is now can confuse the user, and he wonders why the Amperage increases with time.
  • »01.07.12 - 11:31
    boot_wb
    Even with energy.sbar installed, I often accidentally knock out the power lead and don't notice until the computer shuts down.
    Since I've been unable to configure MagicBeacon to notify me when the battery is low, I've written a script workaround which may be useful.
    BattButt
    This checks the battery level every 5 minutes.
    If it's <10%, it notifies the user.
    When the battery is low it also checks if AC power is attached and warns the user.
    Checks increase in frequency when battery is low (3 mins), even more when AC is not attached (90 secs).
    It's easily reconfigured should you need to, and will work out the box. Just double-click the archive, and drag the contents onto your sys: partition.
    To activate it after installation double-click the BattButt icon in WBStartup. (It will start automatically after rebooting.)
    It will use Magicbeacon if installed, falling back to CON: output if MagicBeacon isn't installed.
    Not the most elegant solution, but it works.
  • »22.07.12 - 12:30
    geit,
    Geit
    FYI, I tried using Grunch to install Jadacap's excellent battery level sbar indicator about a week ago and it could not complete the process. I can't remember if it was a download failure, but I think that was the problem. I had already downloaded the file, but could not figure out how to get Grunch to find and use my download, instead of trying to download it again itself, so I was forced into just installing it manually and then I was able to use Grunch to check it to see if it was the latest version.
    Maybe you were aware of this problem already and have fixed it. If not, maybe check the Grunch database to see if it is pointing to the correct download location for this PowerBook battery utility.
  • »23.07.12 - 03:15
