Audio and power button adjustment
    Motosampy
    Posts: 199 from 2004/8/14
    Is there any way to choose audio output on PowerMac ? I have to use headphone connector in front panel to get sound to my speakers in MorphOS, in OSX also back panel line out works fine. Audio preferences do not give any option.
    Also would like to have shutdown function to power button instead of reset, but I guess this is not adjustable atm ?
    (MorphOS 3.1 , PowerMac 3,6 FW800)
  • »16.07.12 - 05:07
    Posts: 2564 from 2003/2/24
    Holding the button for a longer time does not trigger a shutdown ?
    Atleast thats how it works on MacMini and PowerBook. (my QS has reset AND power button so no issue here).
    Bout the audio, there should be no need for that in preferences so you can either hope that this issue gets resolved in a later release (I guess it has been reported..) or just buy an SBLive .....
  • »16.07.12 - 11:08
    Motosampy
    Holding power button down longer time does shutdown, but still would be nice to have possibility to configure the behaviour.
    I have an SBLive on the shelf, but since there's no OSX driver for it I do not want to use it.
  • »20.07.12 - 06:41
