New Mac Mini will not boot MorphOS CD
    XDelusion
    Posts: 602 from 2010/10/27
    My new Mini came in the mail, I can get it to read and boot off of all my Mac DVD's without issue, be they original or a burned back up.
    When in OS X I can read all my MorphOS CD's but can bot boot off them at start time.
    I have tried MorphOS 1.7, 3.0, and 3.1
    I held down C at boot time, and I tried holding down:
    LEFT Command + ALT + F + O.
    Any clues? :(
  • »09.07.12 - 16:02
    Posts: 2577 from 2003/2/24
    a) check if the CDs are readable under OSX (otherwise it might be a case of the dying-superdrive)
    b) if they do read, press ALT on bootup, might get you into that basic bootmenu there is the slight possibility that the CD will boot that way.
  • »09.07.12 - 16:06
    Posts: 1361 from 2004/2/8
    Wireless Bluetooth keyboard perhaps?
  • »09.07.12 - 16:31
    XDelusion
    They read fine under OS X and I have tried two wired USB Mac Keyboards.
    Will try this ALT business.
  • »09.07.12 - 17:38
    XDelusion
    ALT did no good, it still will not see the disc except from within OS X. :/
  • »09.07.12 - 20:27
    XDelusion
    No go, will only detect OS X DVD if I hold ALT.
    Sigh....
  • »10.07.12 - 00:44
    Doffo
    Posts: 508 from 2010/10/14
    My MDD acted weird when I burned MorphOS to a CD-R... Then I tried a blank DVD-R and would finally be picked up, but only once I press the ALT button, then it worked. Never booted from the C button unless I had the OS X install DVD.
    YUUUP!
  • »10.07.12 - 00:48
    Piru
    Posts: 622 from 2003/2/24
    Just to confirm the CD was burnt correctly and doesn't include "morphos-3.1.iso" file on the disk?
  • »10.07.12 - 02:51
    XDelusion
    No Piru, I may be daft, but not that daft! ;)
    The seller mistakenly shipped me an Intel Mac...
    That explains EVERYTHING!!!
    New PPC Mac on the way.
  • »10.07.12 - 19:37
