MorphOS 3.0 bug with Sound Blaster driver and gain?
    redrumloa
    Posts: 1424 from 2003/4/13
    I didn't have this problem with 2.7, but am seeing it in 3.0. I have a Sound Blaster in my Quicksilver. The volume is very low at default settings. I tried to go into pref to raise the gain to like 16.0, but the computer locks up when trying to do something with audio. If I put gain back to 0, no problem.
    Is this a bug? Should it be reported?
  • »29.06.12 - 20:28
    Posts: 2564 from 2003/2/24
    A bit more detail might not hurt, for example which base-setting did you use (here 5 with "EMU10kx" are listed).
    I use "HiFi 16 bit stereo++" with volume at +12 and gain at +22.5db without problem (and none either if I reduce those values).
  • »30.06.12 - 08:06
    redrumloa
    @Kronos
    Just tried again and I cannot recreate it  :-?
    This is what I did initially.
    EMU10kx:16 bit Stereo++
    Volume 0.00
    Gain 16.0
    Not doing it anymore so all's well that ends well.
  • »30.06.12 - 17:12
    redrumloa
    Ah ha! It is doing it again! This time:.
    volume at +12
    gain at +22.5db
    It was working fine at first, then MorphOS would lock up tight as soon as something starts playing sound. I put volume and gain back down to 0 and the problem goes away. This is generic fresh MorphOS 3.0 install with Ultimate Pack 3.0 beta. I doubt Ultimate pack has anything to do with it but I will swap hard drives to one with MorphOS 3 with no Ultimate pack to see if I can recreate the problem.
  • »01.07.12 - 18:22
