SATA on MOS3.0/Powermac
    Sergio
    Posts: 91 from 2005/2/16
    Hi there,
    I have upgraded my PM MDD to MOS3.0, hoping to put my SATA PCI card (sil3512-based) to good use.
    Problem is, when I just plug the card in MOS boots but when I connect my 160GB SATA drive it refuses to boot.
    Any idea how to troubleshoot this situation?
    TIA
    Serge
  • »19.06.12 - 11:07
    You need Mac firmware to boot with the card.
    This was our first reference for the 3512:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=8426&post_id=90898&viewmode=flat&sortorder=0&showonepost=1
    [ Edited by Jim 19.06.2012 - 13:16 ]
  • »19.06.12 - 11:14
    Sergio
    I tried that but the flash tool reported a "bus error".
    What could it mean?
    [ Edited by Sergio 19.06.2012 - 18:55 ]
  • »19.06.12 - 15:53
    Posts: 2553 from 2003/2/24
    @Jim
    No you don't (need a PPC flash).
    Been running a standard PC 3112 for quite a while now.
    Sure I can't coldboot from it, but don't really want (as I keep the HD RDB-partioned).
    A small 4GB CF-card on the onboard IDE does all the hard work (contains both boot-partitions for MorphOS and Linux + an emergency MorphOS) while both MorphOS and Linux (sys: and /root) are on the SATA-drive.
  • »19.06.12 - 16:10
    Motosampy
    Posts: 199 from 2004/8/14
    I got also 'bus error' when I tried to flash the card in my MDD, I flashed it at work in my G5 without any problems
  • »19.06.12 - 17:10
    Motosampy,
    Thanks, I'll keep that in mind when I get around to installing the 3512 based card I have.
    Kronos,
    Neat idea Kronos.
    I hadn't thought of separating the OS like that.
    Actually, my main purpose in buying the SATA controller was to have one of the controllers cabled to an external eSATA connection so I could use my FAT32 formatted external drive (at better speeds then USB allows).
  • »19.06.12 - 17:59
    Sergio
    OK, so
    - any 3112 or 3512 should be recognized and useable by MorphOS
    - to make it bootable and useable under OSX, it must be flashed
    MIne doesn't work under MorphOS so I seem to have a very basic problem. Maybe it is broken and that's why I can't flash it?
  • »19.06.12 - 18:29
    Divinity
    Posts: 498 from 2009/9/8
    @Sergio
    don't flash it (It's not a mac one card); you need to boot from other unit (the HFS for exemple in the PATA inside unit, or in the CF card ...) and use the SATA hd for System:, work: ...etc... in SFS/PFS3...filesystem
  • »19.06.12 - 19:13
    Sergio
    Well for now it won't work neither under MOS nor under OSX, so I have nothing to lose here.
  • »19.06.12 - 19:56
    Divinity,
    I'm not sure WHAT you mean by "its not a mac one card".
    The firmware listed is fairly generic.
    And you can make a 3512 OSX bootable, so I can't see why that wouldn't work under MorphOS.
  • »19.06.12 - 21:27
