Audio
    caver99
    Posts: 131 from 2012/6/14
    AS in previous thread i have a quicksilver(2002).
    This is up and running MorphOS 3.0 and runs well except that i get no audio, i have installed the Giana remake, doom and RTCW but get no audio.
    What i was wondering does the audio come out the front speaker or only out the rear socket?
    When os x 10.5.6 is installed sound comes out the front speaker well.
    I would prefer to get the internal sound to work rather than put an SB card in.
    Powermac quicksilver Dual 1ghz Dual Boot Morph OS 3.7 and OS X 10.5.8
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »17.06.12 - 06:11
    caver99
    Its on its working now i put a set of headphones in and the internal and headphones have started to wok.
    Great i now hove sound in MrphOS.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »17.06.12 - 06:30
    Posts: 607 from 2003/4/11
    It seems that there are different types of analog audio logic within the Quicksilver (PowerMac3,5) model range. We try to sort that out for a future release.
  • »17.06.12 - 12:14
    mdarren
    Posts: 5 from 2012/6/19
    There should be no problem with this as I have implemented something really similar to this and had no problem with it. Though it would be a different thing to consider when you are faced with the problem of the hardware not working completely even with the appropriate drivers installed.
    If that is the case, it would be important to ensure that you have the proper things going that easy.
  • »19.06.12 - 12:41
