Help! I can not put my MorphOS on the Internet
    Ritcho
    Posts: 2 from 2012/5/28
    Hi! I can not put my MorphOS on the Internet...
    I go into "preferences" and the two network cards (internal) and one external (PCI) were recognized. But when I try to access any site I get an error "could not resolve host name".
    Already configured with fixed IP and DHCP. I'm getting discouraged ...
    I have a Mac G4 Dual-Core 1.42 Ghz.
    Thank you!
    Ritcho.
    Ritcho
    RJ-Brazil
  • »28.05.12 - 23:37
    Posts: 3311 from 2003/3/5
    First, make sure only one card is enabled in settings. After saving, open a shell and type ifconfig to see if the interface got configured via DHCP.
  • »29.05.12 - 01:07
    Ritcho
    Hi jacadcaps!
    Thank you for the reply.
    I did attempt to use a fixed IP (all computers in my net have Ip fixed). Another error was the two netword cards enabled. This way, DHCP also dosen't work.
    Finally everything is ok.
    Thank you very much!
    Ritcho
    RJ-Brazil
  • »30.05.12 - 18:46
