install help MAC PPC G4 500Mhz
    digitaldust
    Posts: 4 from 2012/5/10
    Hello all , I hope i'm putting this in the right place. I have gotten the install wiz to go thru till its time to copy files. However the window sits for a long time after it states xx of xxxx copied , then the file copy area is ghosted out. but the drive HD1 is not ghost if i click on the drive then click back on to the install. It copies a larger or smaller number of files. then goes back to being ghosted out as if its not doing anything ,
    after I reboot with no cdrom in the drive I load upto good old amiga wbshell I can type loadwb then it starts up the rest of the loading then i have to endcli
    am i messing this up somewhere and is there a set of instructions.
    thanks
  • »10.05.12 - 16:49
    Posts: 3253 from 2003/3/5
    My bet would be that you've got some problem with a CD drive - which is pretty common with Apple hw. Try another drive.
  • »10.05.12 - 20:59
