Terminal Emulation under MOS 1.4
    AyoS
    Posts: 410 from 2003/8/13
    Can someone give me an Idea of a good Terminal Emulator to transfer files between my A3000 and Pegasos II? I used Term 4.7 020+ twice yesterday, but now it meditates whenever I try to change any options, then after several tries, I rebooted and wiped out (or invalidated) my work(sfs) partition?? :-?
    Thanks
  • »07.01.04 - 01:40
  • Targhan
    Posts: 2833 from 2003/2/8
    AmTelnet is supposed to have Term functions, I think. Just don't use the zmodem option...
    I wonder if someone could convince Cloanto to port their "MyAmiga" software to MorphOS? :-)
    :idea:Targhan
  • »07.01.04 - 01:52
    AyoS
    Thanks, I will try that option, wonder if zmodem is the same problem I had with term.
  • »07.01.04 - 01:56
