Posts: 12537 from 2003/5/22
> MorphOS Poseidon isn't open source iirc.
None of the changes in or additions to MorphOS Poseidon that were made after platon42's open source release in mid-2009 are part of the open source release, true. Everything that isn't MorphOS-specific has been included of course, and the
bounty description says the following regarding the MorphOS-specific parts:
Included will be: [...]
* pciusb.device OHCI, UHCI and EHCI combined host controller driver for MorphOS (AS IS!)
Special notes: [...] pciusb.device is only compilable for MorphOS/PPC and may require access to private MorphOS include files that will not be part of the open source release.
Excluded will be: [...]
* source code for input.device of MorphOS (for obvious reasons)
* MorphOS specific handling of stuff: query.library and mount.library support"
However, I don't know whether what has been open sourced of Poseidon is sufficient to add USB 3.0 support without having access to MorphOS-internal source code.
