Is HP postscript level 3 emulation enough?
    Is HP postscript level 3 emulation accurate enough to serve under MorphOS (as a substitute for Postscript)?
  • »25.01.12 - 18:45
    dake
    Posts: 204 from 2007/9/14
    PS3 works for me!
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7821&forum=11#83051
    [ Edited by dake 25.01.2012 - 21:41 ]
  • »25.01.12 - 19:37
    Posts: 12558 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=7785&start=82
  • »25.01.12 - 20:03
    Thanks Dake (and Andreas of course),
    Apparently I've managed to bring up a topic I've already discussed (yet again).
    Newegg.com has a Xerox laser printer with PCL 6 and 5e emulation for $179.99 and free shipping (with 32MB of memory).
    http://www.newegg.com/Product/Product.aspx?Item=N82E16828118526
    They also have an HP printer with HP PCL 6, HP PCL 5c, HP postscript level 3 emulation listed for $199.99 and $4.99 shipping and handling (with 128MB of memory and network connections).
    http://www.newegg.com/Product/Product.aspx?Item=N82E16828115774
    I think it might be time to upgrade from my HP inkjet.
    [ Edited by Jim 26.01.2012 - 10:50 ]
  • »26.01.12 - 09:49
    Posts: 1390 from 2010/1/6
    The second one is similar to the HP1515n which works well on Morphos (HPGL-Emulation and PS)! It features a web-interface to config printer. But I strongly recommand additional RAM (+256MB)! With 128MB it ist not possible to print a full color A4-sheet, because the complete sheet-data has to be transfered to printer RAM first, before internal processing in the printer will be started.
    Don`t buy original printer RAM from HP! It is crazy expensive - there are other companies which offers the same RAM under normal conditions.....you have to google...
    [ Editiert durch Amigaharry2 30.01.2012 - 14:40 ]
  • »26.01.12 - 10:46
    Thanks, I hadn't considered that issue as 128MB would be adequate for a black only printer.
    Edit - 256MB from Newegg $9.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820134645
    [ Edited by Jim 26.01.2012 - 16:34 ]
  • »26.01.12 - 15:27
    bash64
    Posts: 977 from 2010/10/28
    Beware of the CP series.
    I have the CP1025nw.
    It uses a proprietary protocol called winstream to print.
    Takes a custom driver to make it work with unix.
    It does not have postscript so I don't know if this example applies.
    Do your research before buying.
    [ Edited by bash64 26.01.2012 - 17:28 ]
  • »26.01.12 - 21:27
    > Beware of the CP series. [...] Do your research before buying.
    Obviously, he did and already told about the outcome of it in this very thread (hint: it's in #4).
  • »26.01.12 - 22:21
    As Andreas has pointed out, that is a significantly different printer.
    The CP1525nw supports Postscript emulation which should make it a better candidate.
    We've been hashing this one around for awhile.
  • »28.01.12 - 21:18
    Newegg sends me a offer of 10% off HP Laser printers and when I check it out they've raised the price of the CP1525nw by $20.
    Do they think of these things ahead of time?
  • »06.02.12 - 22:28
