HD > 120Go under Morphos
    Posts: 65 from 2003/2/10
    I plan to purchase a matro HD 160Go... the problem is that it seems HD
    bigger than 120Go are not well supported, by every OS or even PC...
    Does MOS support HD bigger than 120Go ?
    The second problem is that this HD will be external (USB2+firewire) to
    be used by both my PC and the pegasos... Will it support fat32
    partitions ?
    Thanks for your answeres :-)
    N'cha, LorD
    http://www.lordfpx.com/
  • »01.01.04 - 19:02
    AyoS
    Posts: 410 from 2003/8/13
    Hello,
    I know that that the SFS is capable of handling
    far lager partition sizes than 120Gig, about firewire and fat32? someone with more experience will have to answer that... sorry
  • »02.01.04 - 04:13
    Posts: 35 from 2003/6/11
    hi
    usb harddrive with fat32 works fine here. remember to check the drive with mos after formatting and before using it!
    also, keep in mind that a harddisk is damn slow with usb1.1!
    transfer rates will not exceed 500kb/sec by far. so copying a cd image will take you about 20 minutes!
    kind regards
  • »02.01.04 - 12:11
    porneL
    Posts: 49 from 2003/7/16
    For sharing HDD between peg and pc better use ethernet and samba. My peg1 transfers 3,5mb/sec under emulation. With native samba+amitcp (when its ready arrrgh!) it should reach full 100mbit speed.
    this text is here to confuse you
  • »02.01.04 - 12:58
    Thanx for your answeres, but I know about the slowness of the USB1.1
    and I know how to share files with my PC, what I want now is to have a
    mass storage for multimedia files (divx, mp3) on a big external HD.
    I'm waiting for firewire support (till then, I will use the damn slow
    USB1.1 ;-)).
    The real pb is to know if datas beyond 120Go will be corrupted or
    not...
    N'cha, LorD
  • »02.01.04 - 15:47
    magnetic
    Posts: 2129 from 2003/3/1
    AFAIK
    MOS supports up to Terrabyte HD size! This is according to the Core MOS team.
    magnetic
  • »02.01.04 - 21:56
