Moderator
Posts: 2564 from 2003/2/24
There is that crap with the OF needing those padding partitions...
You might make sure that "Boot" is empty (read format). Or even completly remove the partition. If that doesn't help it might be best to start from scratch.
Either follow the instructions in the dualboot.pdf (Install OSX 1st, MorphOS 2nd), or do as I did ...
Install MorphOS, but format the last partition to HFS.
OSX won't install on HFS, but it offers you to reformat it too HFS+. All attempts to just add a partition with OSX-Tiger have failed for me. You would still need to do the OF-macig to reset MorphOS as the default boot (it ends up on hd:2 in this case).
