Should I use a SSD with MOS?
    matt3
    Posts: 784 from 2004/2/10
    Just learning about SSD's and I'm not sure if I should use one for MOS.
    Would you recommend using one for MOS or not?
    Thanks for the feedback.
  • »18.12.11 - 12:05
    stephen_robinson
    Posts: 746 from 2007/4/22
    Never tried it, but I use one on my Amiga 1200 for workbench 3.1 and that's excellent, I've fitted my Powerbook with a 64gb SSD in preperation and MacOS X boots about twice as fast, and the whole thing is silent, I'm just waiting, well you know.. 3.0 to be released.
    SSD should work very well as there's no cache of files, or virtual memory with MorphOS.
    Oh, actually, my Efika has one as well, works great, so yep, recommended from me!
  • »18.12.11 - 13:22
    Posts: 2564 from 2003/2/24
    Had a 32GB one in my MacMini, worked like a charm (and still does now in the Efika).
    My QuickSilver has a MomentusXT combining high capacity (500GB) with SSD-speed (there is also a small IDE-CF-card as boot-device).
  • »18.12.11 - 13:44
    Korni
    Posts: 473 from 2006/2/23
    If you want 0dB noise level then a SSD is for you. I don't have it myself - it's just a bit expensive. Stock HDDs in PowerBooks are quite noisy and not really fast (no surprise, they are old), so they are worth to be replaced anyway. Small benchmark, copying 200MB file to RAM.
    PowerBook5,8; Samsung HM160HC; 50MB/s, really silent.
    PowerBook5,6; Fujtisu MHT2080AH (stock for this model); 30MB/s really noisy.
    PowerMac10,1 (Mac mini); Toshiba MK8026GA (stock for PowerBook5,8); 30MB/s, noisy.
  • »18.12.11 - 14:19
    SoundSquare
    Posts: 1214 from 2004/12/1
    yes, using a SSD is worth it. I use a 64gb SSD in my macmini and booting morphos takes only 2/3 secs. OWB opens instantly. The only downside is that you won't be able to anable TRIM in morphOS if yor SSD supports it. Without TRIM you may experience slowdowns of your SSD in time. But i don't think it would be much noticeable.
  • »19.12.11 - 06:26
    Posts: 2730 from 2003/2/24
    While SSD indeed makes loading/saving faster, I personally don't consider regular HDD loading/saving times to be much of a problem on MorphOS (not like other OS's). Most things you do is kind of instant anyway, even without a SSD. But it does remove the noise coming from the HDD, so if that's important to you, then why not?
  • »19.12.11 - 07:06
    matt3
    Thanks for all the great feedback.
    Since we don't have TRIM, if we do a reformat and restore a backup will that accomplish the same thing?
    Does anyone recommend a particular brand of SSD? I will be ordering a small one to keep the price down. Was thinking of a OWC Mercury Legacy since they provided a HD replacement video for the G4 and seemed to have intel on the G4.
    (Good thing they provide a video, GOOD GOLLY MISS MOLLY it is a ridiculous process. Why didn't they do what most sane manufactures do and use one screw to pull from side and replace in under 3 minutes...  :-/)
    [ Edited by matt3 19.12.2011 - 05:53 ]
  • »19.12.11 - 09:48
    Piru
    Posts: 617 from 2003/2/24
    matt3,
    No, doing format won't TRIM the drive.
    You could however boot into linux and trim from there. The data will be wiped in this operation, however.
    [ Edited by Piru 19.12.2011 - 15:57 ]
  • »19.12.11 - 12:56
    dake
    Posts: 204 from 2007/9/14
    @SoundSquare
    Do you mean 0.67 secs or 2 to 3 seconds? Is this time from power on until morphos desktop ready to use? From firmware to desktop? Sounds impossible but please explain.
    On system startup I have my OWB directory copied to ram: and when I start OWB it still take 0.5 sec on my 1.83Ghz mini, and ram disk is pretty fast. What speed do you have if you copy a big file from SSD to RAM and do the same from RAM to RAM? When I copy a file from ram to ram, Ambient shows 86mb/s + write this 86mb/s also.
    I have thinking about getting on of those SSD's for a long time.
    [ Edited by dake 19.12.2011 - 21:29 ]
  • »19.12.11 - 19:22
