SATA on Pegasos 2 Question
    Everblue
    Posts: 170 from 2004/1/6
    Is it possible to boot a HDD (MorphOS2.7 or OS4.1) directly on a Pegasos 2 motherboard using a Sata PCI card (3512 chipset)?
    Thanks!
  • »12.12.11 - 13:00
    pan1k
    Posts: 147 from 2009/1/20
    AFAIK Nope!
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »12.12.11 - 16:11
    Everblue
    I would have imagined so. Thanks for your reply anyway =)
  • »12.12.11 - 16:19
    Divinity
    Posts: 512 from 2009/9/8
    @Nostromo
    You can boot the OS (MorphOS2.7 and AmigaOS4.1.3) form SATA hd in Pegasos2 (via SATA PCI card supported), but not the kernel (needed a PATA hd inside); SmartFirmware 1.1 or 1.2 needs a PATA one to bootstrap
    [ Edited by Divinity 12.12.2011 - 18:48 ]
  • »12.12.11 - 17:47
