How to tell what Powerbook you have.
    matt3
    Posts: 785 from 2004/2/10
    I'm in the midst of purchasing a Powerbook 17 G4 and the owner doesn't know if it is an 1139 and if it has radeon graphics with 128mb of ram. From what I read the 1139 has to have a clock of 1.67 and can have either nvidia or ati.... He thinks it is an October 2005.
    What is the easiest way to determine this?
    [ Edited by matt3 29.11.2011 - 11:57 ]
  • »29.11.11 - 15:55
    Posts: 12558 from 2003/5/22
    With nVidia GPU it would have to have a 12" screen.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8036&forum=11 (chapter #1 therein)
  • »29.11.11 - 16:53
    osco
    Posts: 680 from 2009/10/20
    Get the serial number: Inside the battery bay: Go to site below: Plug in the #:
    You will get full specifications :) :-)  :-)
    http://www.powerbookmedic.com/identify-mac-serial.php
  • »29.11.11 - 20:48
