Is MorphOS 2.7 compatible with all "Mirror G4" Power Macs?
    macsociety
    Posts: 57 from 2010/1/18
    Local person is selling a single G4 1GHz CPU Mirror Power Mac with 24" ADC Apple Display. Has 1.75GB RAM.
    Will MorphOS 2.7 run on this with sound and all?
    Is there something specific I need seller to look in the OS for to confirm this model system will work for me?
    Thomas
  • »22.11.11 - 01:42
    Posts: 3311 from 2003/3/5
    Just make sure it has a supported Radeon graphics card.
  • »22.11.11 - 01:46
    macsociety
    Sounds like the card that comes with it is not as he tells me it is the NVIDIA GeForce2 MX. So, I guess I would need to buy a new video card.
    Can anone tell me if the Apple ADC Port 24" Display will work with it. This is the special Apple ADC port displays.
    Tom
  • »22.11.11 - 02:27
    redrumloa
    Posts: 1424 from 2003/4/13
    macsociety,
    The ADC port is on the video card. If you buy a genuine supported Mac version ATI Radeon such as 7500, 8500 etc it will have the ADC port. If you buy a PC Radeon that has been reflashed with a Mac BIOS, it will not have the ADC port.
    I have a spare Mac Version ATI Radeon 7500 that I could sell to you for almost nothing.
  • »22.11.11 - 13:25
    macsociety
    redrumloa,
    PM sent about the card.
    So I take it your card is this one shown in the HELP list for compatible video cards on the morphos website?
    ATI Radeon 7500 (RV200) is what they show.
    tj
    [ Edited by macsociety 22.11.2011 - 14:00 ]
  • »22.11.11 - 20:57
    redrumloa
    macsociety,
    Yes, I pulled this card from a Power Mac Quicksilver 2002. It works fine. I will reply to your PM.
  • »22.11.11 - 21:13
    Or you could look for an Apple Radeon 9000Pro or 8500.
    Both would perform better and aren't particularly expensive.
  • »22.11.11 - 21:56
    macsociety
    Purchased the 7500 from redrumola. Thanks.
    Will try this card for now. The price was right.
    Thanks redrumloa
    tj
    [ Edited by macsociety 22.11.2011 - 14:59 ]
  • »22.11.11 - 21:59
