Battery ramblings powerbook 5,8
    osco
    Posts: 680 from 2009/10/20
    Battery Information:
    Charge Information:
    Charge remaining (mAh): 673
    Charging: Yes
    Full charge capacity (mAh): 4603
    Health Information:
    Cycle count: 19
    Condition: Good
    Battery Installed: Yes
    Amperage (mA): 10
    Voltage (mV): 11037
    System Power Settings:
    AC Power:
    System Sleep Timer (Minutes): 0
    Disk Sleep Timer (Minutes): 10
    Display Sleep Timer (Minutes): 0
    Automatic Restart On Power Loss: No
    Wake On AC Change: No
    Wake On Clamshell Open: Yes
    Wake On LAN: Yes
    Wake On Modem Ring: Yes
    Display Sleep Uses Dim: Yes
    Battery Power:
    System Sleep Timer (Minutes): 22
    Display Sleep Timer (Minutes): 22
    Wake On Modem Ring: No
    Reduce Brightness: Yes
    Hardware Configuration:
    Clamshell Closed: No
    UPS Installed: No
    AC Charger Information:
    AC Charger (Watts): 65
    Connected: Yes
    Charging: Yes
    SLOW CHARGING? WHY? IS IT THE BATTERY, HARDWARE, OR CHARGER?
    AMPPERAGE?
    VOLTAGE?
    heading to google
     :-x  :-x
    The battery charges at a rate of 10mAh an hour! // 460 hrs to charge battery? hmmmm? :-?  :-?  :-?  :-?  :-?
    [ Edited by osco 19.10.2011 - 08:13 ]
  • »19.10.11 - 10:08
    Posts: 2564 from 2003/2/24
    Maybe your PMU needs a reset:
    Remove battery
    Remove PSU
    Press power-button for > 5 secs.
  • »19.10.11 - 10:34
    osco
    Reset PMU.....no effect What would happen if deleted?
    if edited? what is the "HIBERNATE MODE"
    <?xml version="1.0" encoding="UTF-8"?>
    <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
    <plist version="1.0">
    <dict>
    <key>ActivePowerProfiles</key>
    <dict>
    <key>AC Power</key>
    <integer>2</integer>
    <key>Battery Power</key>
    <integer>-1</integer>
    </dict>
    <key>Custom Profile</key>
    <dict>
    <key>AC Power</key>
    <dict>
    <key>Automatic Restart On Power Loss</key>
    <integer>0</integer>
    <key>Disk Sleep Timer</key>
    <integer>10</integer>
    <key>Display Sleep Timer</key>
    <integer>25</integer>
    <key>Display Sleep Uses Dim</key>
    <key>Hibernate File</key>
    <string>/var/vm/sleepimage</string>
    <key>Hibernate Mode</key>
    <integer>3</integer>
    <key>Mobile Motion Module</key>
    <integer>1</integer>
    <key>System Sleep Timer</key>
    <key>TTYSPreventSleep</key>
    <key>Wake On AC Change</key>
    <key>Wake On Clamshell Open</key>
    <key>Wake On LAN</key>
    <key>Wake On Modem Ring</key>
    </dict>
    <dict>
    <integer>22</integer>
    <key>ReduceBrightness</key>
    </dict>
    </dict>
    </dict>
    </plist>
    Someone posted by removing (it) made the charger work? :-x
    [ Edited by osco 20.10.2011 - 07:59 ]
  • »20.10.11 - 09:52
    Jupp3
    Posts: 1193 from 2003/2/24
    Are you sure you have PowerBook, not iBook charger?
    PowerBook charger has bigger wattage due to bigger power consumption. With iBook charger, there won't be much extra to charge the battery with...
    -EDIT-
    I think 65 watts should be for PowerBook...
    [ Edited by Jupp3 20.10.2011 - 15:22 ]
  • »20.10.11 - 10:19
    osco
    Have two A1021 chargers 65 watt. Both operate the "5,8" and both only charge at a rate
    of 10 mAh...that,s slow?
    There is a page on the net that is very comprehensive and shows what the powerbook consumes.
    http://www.girr.org/mac_stuff/pb15_battery_life.html
    1. Chargers will check their outputs tonight with a multimeter
    2. Battery Plan to pick a new open box battery tonight
    3. Software Reset PMU, PRAM, firmware
    4. Open up the laptop and check the connections and see if any damage.
    5. DC sound board?
    6. Main Logi Board..
    anything I missed..okay prayer :-)
    [ Edited by osco 20.10.2011 - 15:04 ]
  • »20.10.11 - 16:23
    osco
    Batteries are an issue! Laptop is circa 2005 means batteries are 7 plus years old. if you get a used 5,8 be advised that a new battery is expensive and EBAY and the like will not be an avenue to take. Just bought a new battery that was DEAD. manufactured 2003?
    Cells die at 20% per year means battery 160% dead...  :-o  :-o  :-o  :-o  :-o  :-o
  • »21.10.11 - 14:59
    osco
    Apple has stopped stocking as of Aug/Sept 2011... :-D
    All aftermarket now.
    What to do?
    Buy "new cells" and install ..http://www.youtube.com/watch?v=YKyhNkQzE5E
    Its for an Ibook but same principle
    Find a service that will do it?
    Getting to be a hastle  8-)
  • »21.10.11 - 15:46
    osco
    Jupp3
    What is your amperage on your mac with the charger on and running? 8-)
  • »21.10.11 - 18:31
    osco
    15" PowerBook Battery Life Tests
    Outstanding report!!!
    2nd read
    will do a third slowly
    © 2003-2010 George Schreyer
    Created 26 Sept 2003
    Last Updated June 20, 2010
  • »22.10.11 - 06:57
    osco
    Taking a look at the newer technology site:
    http://www.newertech.com/products/pbg4_batt_al15.php
    http://www.newertech.com/downloads/nwtmanpbbat.pdf
    http://www.newertech.com/downloads/Manuals/batts/newertechbatterysheet.pdf
    http://www.newertech.com/tech_support/newerbatteryconditioning.php
    http://www.newertech.com/tech_support/newertech_batt_instructions.php
    next some sales sites for pricing?
     :-x
    http://eshop.macsales.com/item/NewerTech/BAP15AL52RS/
    $99.00
    http://www.mac-pro.com/s.nl/it.A/id.3211/.f
    $89.00
    Apple sales came up with
    http://www.nextdaypower.com/Apple-PowerBook-G4-15-inch-M9756G-A-Rechargeable-Battery.htm
    $39.00
     :-x
    [ Edited by osco 22.10.2011 - 07:24 ]
  • »22.10.11 - 07:16
    osco
    I now have five batteries  :-D
    and a new external charger  :-) it it came in late yesterday  :-)
    The charger is now REALLY CHARGING THE BATTERY.
    The Powerbook charges at 10amps the external rated at 3500amps.
    It has been weeks of charging by the Powerbook to get it at 70%.
    It appears that the batteries were not the problem but the charging circuit in the Powerbook.
    How to narrow it down?
  • »04.11.11 - 07:22
    kamelito
    Posts: 103 from 2011/9/21
    Which charger did you use? any link?
    Did the old battery is now working? How long did it stand?
    I read (french) that on new macbook pro there's problem like that and they said that by unplugging the battery cable inside the Mac for a few seconds could resolve the problem.
    Kamel
  • »04.11.11 - 09:06
    osco
    AL-3186 $32.61 1 Compatible External Charger for APPLE MacBook A1185, A1175, A1189, iBook A1061, M8433, PowerBook A1022, A1057, A1078, M6359, M7385, M8983, M8984, M9677
    Ships from U.S warehouse.
    www.brilliantstore.com
    I may get another :) 8-)
    I plan to run some consumption tests on the batteries as well as the time to charge an empty battery.
    It means; now I have a truly portable Morph laptop
    [ Edited by osco 04.11.2011 - 06:02 ]
  • »04.11.11 - 09:55
    @osco,
    What did you do to fix your charging problem, since you said that it was not the battery, or the charger that was the problem? Did you replace the DC power board inside the PowerBook?
    If you want to sell one of the good batteries that you have (since you have 5 of them now), let me know, as I could use a spare for those times when I am traveling and it is inconvenient or impossible to plug in the A/C charger to charge the battery and/or run the PowerBook from the charger.
  • »04.11.11 - 11:35
    osco
    I am now calibrating 4 batteries 3 with cycle counts of zero and one with nineteen  :-)
    I haven't yet solved why the 5,8 is only allowing 9 amps to the battery?
    But the four good batteries will allow the freedom to be away from an A/C outlet.
    Waiting for 3.0
     8-)
  • »05.11.11 - 11:42
    boot_wb
    Posts: 874 from 2007/4/9
    Osco, have you tried examining the performance of one of the new batteries under the same charging utility?
    Also, did you notice if the bad battery charged more quickly if the powerbook was switched off during charging?
    Regards
    Rich
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »05.11.11 - 14:35
    osco
    It is an EXTERNAL charger. There are no utilities. This charger and a battery A1078 are by themselves. The laptop does no charging. The PowerBook may need a new D/C sound board or even the logic board. The external charger works well and all batteries
    are fully charged. :-)
  • »05.11.11 - 18:22
    boot_wb
    Hi Osco,
    I meant, have you tried the same utility which you posted in post #1 with one of the new batteries charging through the Powerbook (rather than the through the external charger).
    Reason being that there may be nothing wrong with the charging circuitry of the Powerbook, the low charging current (10mA) could simply be due to the high internal resistance of the failing battery (from I=V/R) at lower capacities.
    Would be interesting to know either way, I suspect for a new(er) battery you may get around 1600mA charging current (since Powerbook seems to operate around 45W) when the battery is drained.
    btw - here's an article on calibrating the charge-state logic of the battery which may also be useful (at least in giving accurate 'power remaining' estimates) :o)
    [ Edited by boot_wb 06.11.2011 - 09:19 ]
  • »06.11.11 - 08:13
    osco
    Of the five batteries ONE is bad and it resists charging by the external charger and will be disposed of but not before an autopsy. The net has yet to give answer to the low amperage heading to the battery. I hope its a software fix, then wiring, then DC board and finally the LOGIC board. last battery soon to be calibrated.
    My thoughts are the Powerbook is for on reason or another is only allowing a TRICKLE charge of 9 mAh.
    laters :-o
  • »06.11.11 - 12:48
    kamelito
    @osco
    What am I missing the list "PowerBook A1022, A1057, A1078, M6359, M7385, M8983, M8984, M9677" do not contains the latest PowerBook that Morphos 3.0 will support right?
    Kamel
  • »06.11.11 - 16:06
    osco
    The model numbers are BATTERIES ie an A1078 is one of Apple's batteries... 8-)  8-)  8-)  8-)  8-)  8-)  8-)
  • »06.11.11 - 18:41
    osco
    One of the steps in the quest to get the PowerBook 5,8 ready for Morph3.0:
    POWER ON THE ROAD
    The Powerbook charging set up has had issues and many corrected by the Mac Pro.
    1. The Chargers capacity, 40/65 Watts, barrel connector wiring, barrel connector, internals of the charger (overheating) and the list goes on
    2. Batteries working time in real world 2 hours or so.
    3. DC board internally being jostled by someone tripping on the power adapter cord.
    That being said, the PowerBook has a HISTORY now and many of the its problems have been addressed and corrected!
    My 5,8 still has a trickle charge and I have not yet find the exact cause.
    With 4 fully charged batteries, the PowerBook can spend the day away from the PLUG.
    External charges work and a night of charging gets the four batteries ready for the next day
    One person's solution below :)
    http://screaminglight.com/projects/technical/powerbook-g4-power-connector-replacement/ :-x
  • »20.11.11 - 08:33
    osco
    My immediate solution was to bypass the PowerBook's charging altogether!
    1.Purchase an external battery charger:
    http://www.brilliantstore.com/apple_laptop_battery_chargers_dekcell_al_3186.html
    2.Purchase 4 new batteries
    http://www.ebay.com/itm/15-Apple-Power-Book-G4-Rechargeable-Li-Ion-Battery/150700215594?ssPageName=WDVW&rd=1&ih=005&category=14295&cmd=ViewItem#ht_500wt_1335
    A day to fly and get recharged at night.
     :-o
  • »20.11.11 - 12:54
    That external battery charger can only charge one battery at a time.
    What do you do, get up in the middle of the night to switch batteries, so all 4 of your PowerBook batteries are charged for the next day?
  • »21.11.11 - 02:14
    osco
    My sleep is jagged and if need be, we will opt for another external. Newer Technology has a pricy DUAL charger as well.
    http://www.ebay.com/itm/Newer-Technology-Battery-Charger-PowerBook-/280774915068?pt=Laptop_Batteries&hash=item415f7d33fc
    In the field, use would be from noon till 5pm and with 4 full young batteries there should plenty with reserves as well. :-P
    Also will look at another WIFI set-up
    http://www.ebay.com/itm/Atheros-AR5212-802-11-A-B-G-PCMCIA-Wireless-Card-Kit-/270563832044?pt=LH_DefaultDomain_0&hash=item3efedc70ec
    Wait for the Ebay page to fully load :) :-x
    Atheros AR5212 802.11a/b/g PCMCIA wireless network card
    [ Edited by osco 21.11.2011 - 01:00 ]
  • »21.11.11 - 04:52
