bad g4 quicksilver
    bash64
    Posts: 974 from 2010/10/28
    My Quicksilver won't power up.
    I removed a sonnet accelerator from it and put the original cpu(s) back in and it worked for a while but now it wont.
    Sonnet had me upgrade the rom so is there anyone out there with a Quicksilver who can use a mac rom ripper and email me a working rom for this machine? I've got to get this thing reburned.
    As far as the power I think there is a circuit breaker on the power supply and that might be the issue.
  • »16.10.11 - 09:17
    Divinity
    Posts: 498 from 2009/9/8
    you can remove the patch in the Open Firmware (installed with the Sonnet card) using the original Apple CPU card.
    you don't need a working Sonnet card to remove the patch in the Open Firmware installed with the Sonnet card.
    If you have """problems""" with original Apple CPU card and Sonnet CPU card, probably your mainboard has problems
    [ Edited by Divinity 16.10.2011 - 21:19 ]
  • »16.10.11 - 18:17
    bash64
    I have a PC power supply tester.
    It shows the apple power supply as faulty.
    However, the apple power supply has two extra connectrs beyond the normal atx. my tester supports up to 4 pins extra beyond atx.
    Will my PC tester give a correct reading?
    There is power coming from the power supply most defintely.
  • »16.10.11 - 23:59
    bash64
    It is fixed.
    Had to reseat the original CPU!
    Thanks
    How far away from a powerbook are we?
    Good time to buy one on ebay.
    :-D
  • »17.10.11 - 00:17
    Posts: 2549 from 2003/2/24
    December is what we've been told in BadBramsted (where I got sold out on PBs *g*).
    Just snapped a WLAN-PCMCIA-card of ebay (10Euro including shipping) which should work with Mr Cafferkey's (sp?) driver.
    Yep, I'm ready !!
  • »17.10.11 - 05:29
    osco
    Posts: 680 from 2009/10/20
    Card bus WPA/WPA2? WHICH MODEL ?
    this reply from a "5,8" hooked to the net wirelessly :-)
  • »17.10.11 - 06:54
    Well someone at the Bad Bramstedt Meeting had such a card on his A1200, and I asked him wether that one would work with WPA. He replied "yes if get the 'gold' edition" searched for that on ebay and snapped it at 6.60+shipping.
    Will post details when it arrives, maybe make a testrun on my A1200 (assuming there is a test version of that driver).
  • »17.10.11 - 07:28
    osco
    I have many cards from Gateway Solo 2500 of old
     :-D
  • »17.10.11 - 07:41
    bash64
    Please provide an ebay link for a similar card so I can see what to buy.
    Also, what model # powerbook is the absolute best to get? I want a 17" one.
    BTW: got youtube to finally work with OWB. The latest copy made it easy.
    Thanks.
     :-o
    P.S. Don't EVER plug a mac PS into a PC PS tester!
    Wow mom, look at the pretty sparks flying everywhere.
    [ Edited by bash64 17.10.2011 - 07:02 ]
  • »17.10.11 - 08:59
    Posts: 12521 from 2003/5/22
    http://www.amiga.org/forums/showpost.php?p=640557
  • »17.10.11 - 09:40
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8036&forum=11
  • »17.10.11 - 09:44
    Very cool. Now we will have laptop support. I guess its time to start looking.
    I assume that also means we will be getting R300 3D support?
  • »17.10.11 - 12:24
    My question on this matter from one month ago went unanswered, unfortunately.
  • »17.10.11 - 15:01
    Apparently my repetition of that inquiry is also going to go unanswered.
    But if Powerbook support includes support for 3D acceleration and that line uses a Mobility 9700 GPU, then doesn't that indicate R300 3D support?
    Or is Powerbook support initially going to forgo 3D support?
  • »18.10.11 - 15:14
    It does, except when PowerBook support does not include support for 3D acceleration ;-)
    That's the question exactly. I guess we will know the answer no later than the MorphOS 3.0 release :-)
  • »18.10.11 - 15:46
    Is that the next release (forgoing a 2.8 release)?
  • »19.10.11 - 14:31
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8022&forum=3&start=12
  • »19.10.11 - 15:10
    Eventually, some MorphOS Team member stooped to answer your inquiry from another site:
    "There will be 3D support"
    http://www.amiga.org/forums/showpost.php?p=666854
  • »07.11.11 - 21:35
    Addendum:
    This seems to be confirmed now:
    "3D Driver R300 (Radeon 9700 for PowerBook)."
    http://translate.google.com/translate?sl=fr&tl=en&u=http://www.meta-morphos.org/article.php?sid=1145
  • »13.11.11 - 11:12
    According to Fab and opposed to what itix claimed, MorphOS 3.0 will *not* come with 3D support for R300.
  • »14.11.11 - 09:32
