Quicksilver 2002 Internal Speaker
    weGuru
    Posts: 4 from 2011/6/23
    I was gonna play some Mp3 just to test. But no sound is comming out of the internal speaker on my Quicksilver. Ive tried different settings in the Sound Pref but no go. Am i doing something wrong?
  • »03.08.11 - 23:34
    MarK
    Posts: 641 from 2004/1/25
    well, afair, mine (fw800) worked fine without any settings, so first check, if the speaker is well connected...
    but according to mos team: audio is currently only supported for PowerMac3,4 to 3,6 models. isn't this your case?
    bye, MarK.
    [ Edited by MarK 04.08.2011 - 09:26 ]
  • »04.08.11 - 05:24
    Krashan
    Posts: 1107 from 2003/6/11
    Quicksilver 2002 is PowerMac 3,5, so should work.
    [ Edited by Krashan 04.08.2011 - 08:52 ]
  • »04.08.11 - 05:51
    weGuru
    It works now. The weird part is that i had to plug a headset into the back of the machine before it worked. No it even playes without the headset..Weird computer
  • »04.08.11 - 09:40
    Oli716
    Posts: 16 from 2011/9/18
    Another question about the internal speaker.
    I bought a Quicksilver 800MHz 3.5 and are using a G15 keyboard, so i have no keys for tuning the volume.
    Is there any possibility to adjust the volume of the startsound?
    Is there something like a setup menu where i can adjust this at boot?
    It's very loud by standard setting, therefore i did disconnect it, but without sound is little bit boring now.
    Thanks for your help :)
  • »23.09.11 - 14:28
    pampers
    Posts: 1068 from 2009/2/26
    AFAIK this can only be done from OSX side.
    MorphOS 3.x
  • »23.09.11 - 15:24
    Posts: 2564 from 2003/2/24
    Boot into OSX (yeah I know that sucks) and turn the volume down there.
    Should stay o.k aslong as you don't turn it up again in OSX.
    (startupsoundprefs.pane seemed to be non-working on my QS)
    Optimal solution:
    Disconnect internal speaker, install SBlive ....
  • »23.09.11 - 15:25
    Oli716
    thnx for the help, have to install OSX first ;(
  • »23.09.11 - 18:28
