Recognition/Playing of Audio CDs
    MrZoon
    Posts: 48 from 2003/6/1
    Audio CDs - If I put one in my CDRW drive, and try to mount CD0:, I
    get a message stating that the device is already mounted. Yet, if I
    then try to do something like cd CD0:, I get a device missing message
    (or words to that effect). Info shows "Not a DOS disk", which
    makes sense since it *isn't* a DOS disk.Should any of the player
    tools be able to play an audio CD? Like MPlayer, SoundPlayer, etc.?
    I'm fairly certain I have the audio cable connected internally, but
    the only way I can hear anything is through headphones.
    MrZoon ~8
  • »23.12.03 - 16:07
    Black_Eagle
    Posts: 70 from 2003/6/5
    I still use OptyCDPlayer for Audio CDs, just set it to ide.device and your CD's unit (mine is secondary master = 2)
    OnyxSoft - Amigans never surrender, they know they can do it better...
  • »23.12.03 - 16:37
