Posts: 331 from 2003/5/12
@HAK:
If you are talking about screenmodes in Ambient then
a) check Settings/System settings.../ModeEdit whether you have alredy defined a screenmode you wish to use
b) check Settings/System settings.../Screenmode and edit the Ambient settings to the desired screenmode
I managed to get that sorted eventually. Not sure what I was doing wrong there.
Just a really wild guess: Is your modem connected to the serial port?
Yes.
If yes it *might* be that some debug information will be sent to it.
Ahh - why would this not happen with the Radeon?
You can sent debug information to ram by setting the option "ramdebug" to your boot-file settings in OF (e.g. setenv boot-file boot.img ramdebug).
Thanks. I'll try that tonight.
Robert.
