No display with Phreeboard
    Coder
    Posts: 296 from 2003/3/5
    I am doing a quick test of the board and I don't get any display. They are the same components I used before (gfx / memory) and they still work since I tested it on my A1SE. There is power since all the keyboard lights come on. I also changed the cmos battery to be sure. Any ideas or suggestions since I got the feeling I am overlooking something.
    Coder
  • »14.05.11 - 08:55
    Posts: 2564 from 2003/2/24
    Peg1s can be very picky when it come to RAM.
    But back in the day (read 2002) my Peg1 also seemed DOA until I once connected another puter to look for the serial debug.
    Afterwards it booted regardless of serial connection......
  • »14.05.11 - 10:51
    Coder
    @Kronos
    I am trying to setup a serial debug at this moment. I am just thinking that the only thing different is the keyboard. Is it that picky it won't display without a) kb connected b) not supported kb?
    Coder
  • »14.05.11 - 14:37
    analogkid
    Posts: 719 from 2004/11/3
    IIRC using no keyboard at all is not supported on Peg1. But I'm not sure if you should at least see the BIOS message of the gfx card.
  • »14.05.11 - 14:59
    XP ??? :flame:
    Isn't there "HyperTerminal" somewhere preinstalled (I think that one came with XP, or was it 98 ??).
    Otherwise just google for it...
    Settings should be:
    115200 8n1 (8bit no parity 1 stop bit)
    [ Edited by Kronos 15.05.2011 - 11:55 ]
  • »15.05.11 - 07:52
    Krashan
    Posts: 1107 from 2003/6/11
    PuTTY does the job as well.
  • »15.05.11 - 11:51
    Crumb
    Posts: 736 from 2003/2/24
    have you tried to use a normal Virge PCI graphic card (instead of AGP) to see if there's display output?
  • »16.05.11 - 18:13
    Crumb
    Too bad :-(
    Have you tried different memory modules? try 100Mhz and 133Mhz ones.
    Maybe adding a new coin battery would help.
    PS: Teraterm is a good terminal program for XP. Remember that your serial cable must be "null modem".
  • »19.05.11 - 18:19
    Coder
    @Crumb
    I tried two different modules but no luck. I used the one from the A1Se which still works and worked in the Peg before. I used the cmos battery from the A1SE.
    I will try to score a new serial cable.
    Coder
  • »24.05.11 - 17:54
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 06.09.2011 - 07:29 ]
    Pegasos2 G3, 512 megs RAM
  • »28.05.11 - 09:37
    magnetic
    Posts: 2129 from 2003/3/1
    coder
    The batt it would not be, its not a Teron aka Amiga 1....
    man Phreeboard havent heard that term in a while! :)
  • »30.05.11 - 04:44
    Yay! Play Freebird!
  • »01.06.11 - 01:08
    Coder
    @Velcro_SP
    I have no IDE cables connected to the board. I always strip it to a minimum. Surely it does not need a HD to be connected to display, right?
    Coder
  • »04.06.11 - 07:38
