Brother MFC-9320CW
    dake
    Posts: 204 from 2007/9/14
    The headline say: "Brother MFC9320CW Multifunktion Color Laser Copy Print Scan Fax Network 16ppm 35pages ADF 64MB PCL6\PS3 FTP Scan 250 sheet"
    It looks like this printer have postscript and does that mean it will work in MorphOS?
  • »15.04.11 - 10:17
    Posts: 12537 from 2003/5/22
    Yes.
  • »15.04.11 - 10:24
    dake
    Thanks Andreas for your quick answer, as always.
  • »16.04.11 - 09:20
    dake
    Today I get this bastard home, but when I try to print from MorphED I get some 3 or 4 garbage characters and then the text?
    When I print from APDF I only got garbage, nothing else.
    Anyone get a Brother printer working? and what config do you use in printer prefs?
    Is there something strange regarding PS3 vs Postscript??
  • »19.04.11 - 16:28
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7040&forum=3&start=6
    http://en.wikipedia.org/wiki/PostScript#PostScript_3
  • »19.04.11 - 16:45
    dake
    Finally I get this bastard printing. In printer prefs I choose HP_DeskJet950C, I change Density in Config tab to 300x300dpi and now it prints perfectly fine B/W and Color.
    I had alot of problem with this because you can't add a new printer and press save to use it, you must also reboot before you can print with the newly added printer, of course I didnt know this, I just continue to add new printers and no one worked:(
    I tried alot of different printers but didnt get higher density than 300x300dpi to print correctly, Is there anyone that succeed to print 600x600dpi correctly with a color laser printer?
    Thaks to Andreas_Wolf and to Geit@Morphos
  • »20.04.11 - 17:39
    _bigdan_
    Posts: 70 from 2009/1/7
    It would be great... i've made few tries on old 1270N for B&W 600dpi with Linux Turboprint drivers.
    The MFC9320CW seems great but obviously, modern printer drivers would be fine... The MFC-9970CDW seems very pleasant too !
    bigdan
  • »30.04.11 - 04:15
