Glad you got it figured out and fixed. I also have a MacMini that I need to replace the DVD drive with a different one. It works most of the time, but there are times when it does not work reliably, so I am pretty sure that it is just a flaky DVD drive. I have resisted replacing it so far, as I want to buy some more RAM for it and swap both at the same time. 512mb RAM is okay for almost everything, but 1gb would be better.
