Partition problem
    hatta
    Posts: 2 from 2011/4/10
    I hope this is the right forum for this question.
    I'm trying to install MorphOS on a PowerMac with a
    clean install of OS X 10.4. I've partitioned as described
    in the PDF guide, and installed OS X. When I boot
    the MorphOS CD and get to partitioning, the partition
    manager shows me two of every partition I created under
    the OS X installer. There are also a bunch of little
    28k and 256k partitions scattered around. None of these
    partitions are usable by the installer, which pops up a
    little bubble telling me the max size of the partition
    is zero.
    Have I done something wrong? Is there a workaround
    for this? Any advice is appreciated.
  • »10.04.11 - 19:05
    Posts: 12521 from 2003/5/22
    > the partition manager shows me two of every partition
    > I created under the OS X installer.
    See this thread:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7586&forum=9
  • »10.04.11 - 20:48
