Screen Res
    Marco
    Posts: 10 from 2011/4/9
    first of all i want to say i am new to morphos
    i am getting a new led t.v end of this month and was hoping to use the mini on it
    will morphos do 1900x1080. at the minutes i am using a normal monitor.
  • »09.04.11 - 14:39
    Posts: 3311 from 2003/3/5
    1920x1080 will work just fine, hope you do have the 1.5GHz model though - otherwise memory will be tight.
  • »09.04.11 - 14:52
    Marco
    yes it the 1.5ghz with 64mb ram.
    thanks for the reply looking forward to registering
  • »09.04.11 - 15:10
    pampers
    Posts: 1068 from 2009/2/26
    Hi Marco
    I hope you will enjoy MorphOS as much as we do in here :) Can I ask you a question? Where or how did you find out about MorphOS ?
    MorphOS 3.x
  • »09.04.11 - 16:01
    Marco
    @pampers
    i was cleaning the loft out a few weeks ago and came across an a1200 thats been up there for 15+ years, to get it running again i was reading up online and came across a morphos reference on amigaworld.net. finding out that you could install on a macmini i did just that, i have also installed the ultimate pack
    its seems a nice little os so far and dam fast
    the a1200 is on hold until the cf card and adaptor arrive - as the hard drive just clicks
    is it you that does the ultimate pack?.. somewhere i read that you could use an arexx script to play flash in mplayer while surfing with obw but unsure where i read it as i have been on sooo many sites since finding the a1200 how would i go about this or would i be better opening a new topic in a day or so
  • »09.04.11 - 16:52
    Posts: 12537 from 2003/5/22
    That's the chap who compiles it: https://morph.zone/users/191.html
    Yes, that would be http://aminet.net/package/comm/www/getvideo-0.29 (it's in the Ultimate Pack btw). But it's only a stopgap. The order of means in which video support using OWB can be leveraged should be:
    1. Use website's own HTML5 video mode.
    2. Use userscript for client-sided HTML5 video (only Youtube for now).
    3. Try spoofing as iPad (and disabling the Flash plugin), often resulting in either HTML5 video or direct video link.
    4. Use getvideo ARexx script.
  • »09.04.11 - 17:16
