Pegasos I April II and two graphics cards
    number-one
    Posts: 17 from 2005/8/25
    Hello,
    Is there anyone have two graphics cards working in Pegasos I April II ?
  • »04.04.11 - 13:21
    Crumb
    Posts: 736 from 2003/2/24
    IIRC the problem was that SmartFirmware initialized just one gfx card. Voodoo drivers initialized the card directly without an x86 emulation. Perhaps I'm mistaken, but I think you had to fit a Radeon AGP to boot from it and a Voodoo3/4/5 PCI that should work because 3dfx drivers didn't make use of BIOS emulation at all.
  • »04.04.11 - 19:19
    number-one
    I tried Voodoo 3 3000 PCI + Ati Radeon 7000 AGP and the Pegasos freeze at Morpĥos Boot Picture on the Voodoo output.
  • »04.04.11 - 19:27
    Drako^lM
    Posts: 144 from 2005/8/10
    How well I remember you need Voodoo on AGP and Radeon on PCI
    Hardware :
    Power Mac G5 2.3 Ghz & MorphOS 3.18 & OSX 10.5
    Mini G4 1.5 Ghz & MorphOS 3.18
    BlaBla Team Member -> http://blabla.ppa.pl
    AmiParty Team Member -> http://www.chal.pl/
  • »04.04.11 - 19:42
    CountRaven
    Posts: 566 from 2007/12/10
    Forgive the question but why someone may need two gfx cards on a Peg1?
  • »04.04.11 - 23:38
    number-one
    to connect two monitors with one screen on each.
  • »05.04.11 - 04:12
    Posts: 3279 from 2003/3/5
    AGP Voodoo + PCI Radeon combo should work. It won't work the other way around.
  • »05.04.11 - 04:40
