Posts: 2217 from 2003/2/24
MorphOS sees (and mounts) the external USB drives fine. I haven't had any problems with that ever on Mac minis or Peg1.
Only problem I've had with one 2.5" HD enclosure which I populated with a separately bought 2.5" drive. I think it's because it doesn't get enough current from USB ports, because on mini it just keeps clicking without starting spin properly. On Peg1 it starts, but drops pretty often. I don't know if it usual with 2.5" drives without PSU or just with the one I have.
But all 3.5" devices with separate PSU have worked fine. I've transferred quite many terabytes with Lacie's 250GB, Buffalo's 1TB and WD's 1TB drives without a single problem. Also dozen of different USB memory drives / card adapters have worked fine.
I've mainly used FAT and SFS filesystems.
[ Edited by jPV on 2011/3/14 18:42 ]
