Scored a Digital Audio G4 1.8Ghz, 1.5GB, Radeon 9800 for $10
    redrumloa
    Posts: 1424 from 2003/4/13
    I just got it home and I am setting it up right now! It also has a DVDRW and SCSI card. This is going to be a lot of fun.
    Any word on 3D support doe the Radeon 9800? Beta drivers maybe?
    -EDIT-
    Fixed typo, paid $100 and not $10.
    [ Edited by redrumloa on 2011/1/30 13:33 ]
  • »30.01.11 - 16:50
    That is a great find!
    The SCSI card won't be supported by MorphOS2.x (yet) and I think the 9800 video card will only be supported with 2D, not 3D.
    You would have to ask the MorphOS Dev. Team directly about the possibility of testing any beta video drivers, but I wouldn't get your hopes up on that being granted. I think they have all the beta testers that they need/want.
    Let us know how your installation of MorphOS2.7 goes on that $10 system.
  • »30.01.11 - 17:03
    redrumloa
    I did a typo, I paid $100 not $10.
    Thanks for the advice.
  • »30.01.11 - 17:34
    redrumloa
    I see now that I did not do a typo, the forum truncated my post.
  • »30.01.11 - 17:37
    Simon
    Posts: 809 from 2008/7/6
    I have a similar Powermac, works very nice. But I use a Radeon9000pro 128MB in it. I did pay a lot more for it... good find !
    [ Edited by Oepabakkes on 2011/1/30 21:05 ]
  • »30.01.11 - 17:50
    pampers
    Posts: 1061 from 2009/2/26
    Score! Nice one indeed :)
    MorphOS 3.x
  • »30.01.11 - 17:56
    Posts: 12521 from 2003/5/22
    > SCSI card
    Was said in November to be supposed to be supported in MorphOS 2.8.
    Was said in November to come soonish, somewhen after MorphOS 2.8.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7464&forum=11&post_id=78798#78798
  • »30.01.11 - 18:07
    Posts: 2079 from 2003/6/4
    Great catch. Enjoy!
  • »30.01.11 - 20:49
    Divinity
    Posts: 498 from 2009/9/8
    @redrumloa
    about your 7448 G4 card:
    http://morphos.de/releasenotes-2.7.html
    "Experimental PowerPC 7448 support"
    @Andreas_Wolf
    about SYMBIOS SCSI PCI or Adaptec Mac SCSI PCI ?
  • »30.01.11 - 21:34
    About the ones that are currently supported on the Pegasos.
  • »30.01.11 - 22:10
    Ruud
    Posts: 335 from 2009/2/2
    Nice score indeed. I have the 2Ghz version of that Newertech upgrade. Morphos seems to work ok with it, although occasionally it seems to get stuck on boot. If you feel inclined, overclocking is very easy with these boards - I'm testing mine at 2.13Ghz (the fastest it will go without modifying the board) at the moment. Just for fun because what other point is there? ;)
    Also i've replaced the two noise generators on top of the heatsink with one quiet Noctua 92mm fan running at full speed. Much quieter and heat doesn't seem to be a problem.
  • »30.01.11 - 22:30
    redrumloa
    Power Supply was bad, had to convert an ATX power supply. I'm downloading 2.7 now, may not get a chance to play tonight. Oh well, after work tomorrow.
  • »31.01.11 - 02:51
    Did you get the ATX power supply to fit into the Digital Audio's case? And did you use a 24 to 20 pin adapter to make the re-wiring easier or did you just move the connection pins?
  • »02.02.11 - 18:20
    redrumloa
    The ATX power supply fit into the Digital Audio's case perfectly, no problem. I did not have any 24 to 20 pin adapters handy, so I took a spare ATX power supply and cut off the 20 pin adapter and used the connector from the Digital audio power supply. The pinout is different, so I had to re-wire. The computer works like a champ!
    [ Edited by redrumloa on 2011/2/2 15:13 ]
    [ Edited by redrumloa on 2011/2/2 15:14 ]
  • »02.02.11 - 19:13
    XDelusion
    Posts: 602 from 2010/10/27
    Lucky lucky lucky!!!
    I'll trade you my eMac for your latest find!!! :)
  • »08.02.11 - 02:00
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    Hi Red
    Didn't know you were over here now also.
    Good find on that machine. The only thing I don't like about my mini is the lack of uprade possibilites, apart from crazy oc with removing resistors and faster bigger HDD and more ram.
    Have fun with the machine
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »08.02.11 - 10:33
