Multiple GFX card in Powermac
    Posts: 12537 from 2003/5/22
    > About my CPU ... it's a 7540, I got the heatsink of to double check.
    Woohoo, the fabled Motorola G5 ;-)
  • »30.10.10 - 14:08
    stephen_robinson
    Posts: 746 from 2007/4/22
    I've seen something similar when I put my Mac Mini onto a less that good TV/monitor but it didn't detect the actual monitor, in that case I had to change the frequency, can't quite remember if it went from 60Ghz (mHz?) to 72, or was it the other way?
    Anyway I had to change the screen frequency on both MorphOS and Mac OS X.
  • »30.10.10 - 14:14
    > 60Ghz (mHz?)
    Horizontal frequency would be kHz, vertical frequency would be Hz.
  • »30.10.10 - 14:25
    Simon
    Posts: 809 from 2008/7/6
    nitpicking...
    [ Edited by Oepabakkes on 2010/10/30 21:29 ]
  • »30.10.10 - 16:28
    >>> 60Ghz (mHz?)
    > nitpicking...
    The question mark made it seem like a question :-)
  • »30.10.10 - 16:32
    Simon
    Yes I know it was 7450 and not 7540 ... nitpicker :-)
  • »30.10.10 - 16:35
    stephen_robinson
    As in, it's 60 something HZ, but I'm too busy to check. And if I do wait until I check there's a good chance I'll forget or just not bother so I thought post it in an semi-incomplete way, as it my help a brother out.
    http://tinyurl.com/35q55be
    [ Edited by stephen_robinson on 2010/10/30 21:55 ]
  • »30.10.10 - 16:50
    It was just too tempting ;-)
  • »30.10.10 - 17:44
    That's been my intention as well. If you don't appreciate that bit of information I gave I'm fine with that though.
  • »30.10.10 - 17:50
    Simon
    So in my quest for multiple GFX card, I did another experiment today. I just scored 3 powermacs for parts today for 30€, one being an older PCI powermac with a PCI Ati Rage in it.
    So I installed the Rage in my Powermac3.4 hoping it would work while my voodoo4 doesn't . Well no luck again ... I suppose that Ati rage driver doesn't work on pci cards ? The card doesn't appear in the preferences.
  • »07.01.11 - 18:00
