Can we talk about the PS3 again, now?
    Posts: 12537 from 2003/5/22
    > PS3 easly show 1080p AVCHD videos
    I guess Jim referred to use of the Cell PPE only, i.e. without using the SPEs. AFAIK the PS3 can't play 1080p video without using the SPEs.
  • »02.01.11 - 07:42
    Jupp3
    Posts: 1193 from 2003/2/24
    Could be wrong, but I'd assume there's quite a bit of GPU acceleration going on aswell.
    Remember that a mere single core Intel Atom CPUs with nvidia ion can also easily play 1080p video, if the video codec happens to be one there's enough GPU acceleration for.
  • »02.01.11 - 14:46
    I was absolutely only refering to the power of the PPE. I'm not sure how SPes would be programmed under Linux and I don't expect either Linux or AROS to initially benefit from them.
    Andreas provided the benchmark that pretty much makes this case only a few posts ago
  • »03.01.11 - 01:07
    jcmarcos
    Posts: 1178 from 2003/3/13
    clr666 wrote:
    Slower? But PS3 easly show 1080p AVCHD videos
    Specific functions in custome processors can easily and cheaply smoke powerful general use CPUs. For example, there are handheld devices (cameras, phones) that not only decode, but also ENCODE some forms of high definition video... ON BATTERIES!
    It's not magic, it's engineering (as some shampoo TV ad says) :-D
  • »03.01.11 - 06:28
    > I don't expect [...] Linux [...] to initially benefit from them.
    Linux on PS3 exists since the release of the PS3 itself and has made use of the SPEs since the beginning. See for example the spu-medialib I linked to previously.
  • »03.01.11 - 18:09
    Yes, that was a poorly thought out statement. Linux should make SPE use almost transparent. I couldn't find any references on how Linux handle such an odd asymetrical combination (since coprocessora are more commonly implemented on a 1 to 1 ratio with a main processor)..
    I'll have to spend a little time looking into this. Thanks.
    [ Edited by Jim on 2011/1/4 22:02 ]
    [ Edited by Jim on 2011/1/4 22:06 ]
  • »04.01.11 - 19:59
    Some IBM articles:
    http://www.ibm.com/developerworks/power/library/pa-linuxps3-1/
    http://www.ibm.com/developerworks/power/library/pa-linuxps3-2/
    http://www.ibm.com/developerworks/power/library/pa-linuxps3-3/
    http://www.ibm.com/developerworks/power/library/pa-linuxps3-4/
    http://www.ibm.com/developerworks/power/library/pa-linuxps3-5/
    http://www.ibm.com/developerworks/power/library/pa-linuxps3-6/
    http://www.ibm.com/developerworks/power/library/pa-tipspu1/
    http://www.ibm.com/developerworks/power/library/pa-tipspu2/
    http://www.ibm.com/developerworks/power/library/pa-libspe2/
    http://www.ibm.com/developerworks/power/library/pa-tacklecell1/
    http://www.ibm.com/developerworks/power/library/pa-tacklecell2/
    http://www.ibm.com/developerworks/power/library/pa-tacklecell3/
    http://www.ibm.com/developerworks/power/library/pa-tacklecell4/
    http://www.ibm.com/developerworks/power/library/pa-specode1/
    http://www.ibm.com/developerworks/power/library/pa-specode2/
    http://www.ibm.com/developerworks/power/library/pa-cmpware1/
    Edit: Added some more.
    [ Edited by Andreas_Wolf on 2011/1/5 17:26 ]
  • »04.01.11 - 20:58
    Wow! That's exactly the info required.
    Thank you Andreas.
    I knew IBM had a software library for the Cell, but II wasn't aware of how well the SPEs were supported under Linux.
    BTW - I do have to again appologize for suggesting this processor as a candidate for MorphOS. As I get a better appreciation for its unique design, I realize just how different it is (then a standard PPC).
    [ Edited by Jim on 2011/1/5 4:20 ]
    [ Edited by Jim on 2011/1/5 5:13 ]
  • »04.01.11 - 23:07
