USB tablet
    MarK
    Posts: 641 from 2004/1/25
    hi, does anyone here use any tablet with MorphOS? I bought a Genius EasyPen i608, and with MOS 2.5 it wasn't recognised, imo tablet is a great device for handwriting/drawing, and so it would be great to have a support for them... Can't be so difficult to write a driver :)
    thanks and bye, MarK.
  • »16.12.10 - 05:54
    Posts: 2732 from 2003/2/24
    It doesn't even work as a mouse? Well, afaik there is at least special support for Wacom tablets:
    http://www.platon42.de/poseidon.html
  • »16.12.10 - 06:13
    MarK
    unfortunately no, i haven't tried it for several months, so i'll try it asap again...
    bye, MarK.
  • »16.12.10 - 06:17
    bash64
    Posts: 977 from 2010/10/28
    Wacom was big for Amiga even leading up to 2000. They were supported AFTER Commodore went bankrupt. I wrote a big article on them and their products.
  • »16.12.10 - 08:59
    Posts: 1361 from 2004/2/8
    I got a cheap Trust TB-1100 tablet and it worked straight away (I just had to fiddle with Poseidon prefs a bit - to manually change the drawing area).
  • »16.12.10 - 09:01
    Yomgui
    Posts: 348 from 2004/8/31
    The problem of the poseidon HID driver is there not tool id support: so for all tabler it exists only one tool: a pen.
    Bye bye brush, eraser, etc...
    it's mainly due to input.device/intuition doesn't handle that also.
    (except if you make your own driver)
    Note: The i608 is not "EasyPen", it's a "MousePen".
    [ Edited by Yomgui on 2010/12/16 14:25 ]
    And now... next project!
  • »16.12.10 - 11:11
    Yomgui
    Mark: what are VID/DID of your tablet?
    it's 0x5543:0x0005 ?
  • »16.12.10 - 11:30
