powermac freezing when using UAE
    Simon
    Posts: 809 from 2008/7/6
    Powermac freezes when emulating in UAE (and SNES and ... )
    At the first I tought it was my overclocked 1ghz DP cpu running @ 1.2 GHZ but I now have a 1.8ghz Sonnet and it still happens.
    It's difficult for me to determine what the problem is. I swapped ram also but that didn't change anything.... is it possible that it AHI together with my Audigy doing this ?
  • »13.12.10 - 16:02
    Posts: 3274 from 2003/3/5
    Well... if you have a suspect already, try running the apps without the card plugged in. Random crashes with multiple cpu-gobbling apps could suggest a hardware (cooling?) issue in general though.
  • »14.12.10 - 05:55
    Ruud
    Posts: 335 from 2009/2/2
    I've had problems with Soundblaster Live! and Audigy cards on both Powermac & Pegasos causing freezes. So I'd say it's certainly a plausible suspect.
  • »14.12.10 - 12:47
    I would suspect an overheating problem like Jacadcaps suggested. I hope it is not a conflict with the Soundblaster Live or Audigy card.
    [ Edited by amigadave on 2010/12/14 9:41 ]
  • »14.12.10 - 15:41
    bash64
    Posts: 972 from 2010/10/28
    Did it ever work at any point?
    Cannot eliminate software problems till you get it at least working consistently.
    I had a lot of problems with ROM files.
    I did at one point remove a ram stick that was questionable to get some crashing to stop that was going on when I first got this machine.
    Everything else has been software related.
  • »14.12.10 - 18:02
