SCSI for G4 PowerMacs & MorphOS???
    I just saw this (Click Here) and it got me wondering about supported SCSI PCI cards that work with MorphOS2.7 & MacOSX in a G4 PowerMac. I don't know enough about Adaptec SCSI controllers to know if they are compatible with any of the listed Symbios SCSI controllers that work with MorphOS2.x, but I would of course prefer a faster & newer 68pin or 80pin UW SCSI-2, or SCSI-3 PCI controller card. But even old 50pin controllers would be useful to connect some of my old external SCSI devices or hard drive towers to my MorphOS2.x G4 PowerMac. I like the idea of being able to connect my Amiga SCSI gear to my G4 MorphOS PowerMac and with the Catweasel installed I could also use an Amiga keyboard and mouse instead of what I am using now, although I will probably stay with a 3 button scroll USB mouse.
    Let me know if you know where I can get a MorphOS supported SCSI-2, or SCSI-3 PCI controller card that works in a G4 PowerMac. Hopefully with an external and internal connector and a low price.
  • »09.12.10 - 00:09
    As far as I've heard, we're not getting SCSI support for the Powermac until a later revision. I have a Symbios SCSI controller in my Powermac that I use when running Ubuntu.
    BTW, while based on an older standard, the Symbios controllers (supported by MorphOS) do have a 68 pin connector.
    When MorphOS supports the use of these controllers on a Powermac, I'll try tying a later drive to the controller (I've got a U320 drive around here somewhere). I've already exchanged some messages with other users using U160 drives on this controller, so it may be possible to use these drives as well.
  • »09.12.10 - 01:02
    Posts: 12537 from 2003/5/22
    > in a G4 PowerMac.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7445&forum=11&start=8
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7445&forum=11&start=11
    There's nothing in the MorphOS 2.7 release notes that indicates any change of that status. But there was something said about when it's supposed to change:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7464&forum=11&start=18 (point #3)
    I take it you mean U2W SCSI and U3W SCSI, whereas SCSI-2 and SCSI-3 are the predecessors. According to http://www.morphos-team.net/hardware.html ("Symbios 89x") the best you can get for MorphOS is the 53C896, which is dual-channel U2W SCSI. There also seems to be a 53C897 (pages 227/228) but I don't know its difference to the 53C896.
  • »09.12.10 - 07:37
    The 53C89x is U2W SCSI.
    > a 68 pin connector.
    Not all NCR/Symbios/LSI SCSI controller chips supported by MorphOS comply to a 16 bit wide SCSI spec version (i.e. 68 pins), e.g. the 53C710 supports only 8 bit mode.
  • »09.12.10 - 09:22
    Quite right, no support in 2.7, so it will be a later version before we get any SCSI support in our G4 PowerMacs with MorphOS. I was thinking out loud of the future support that I am hoping for.
  • »09.12.10 - 14:30
    Yep, I haven't seen the 896 Andreas mentioned, but I own an 895 and I can confirm it will work on a Powermac (just not under MorphOS or OSX - yet).
  • »09.12.10 - 20:18
