PtpDigCam usb binding issue
    bash64
    Posts: 972 from 2010/10/28
    After upgrading to MorphOS 2.6 and from an efika to a power mac the PtpDigCam program will not work. Poseidon seems to work ok with my kodak camera, binds the same.
    The app can detect if you have a camera plugged in or not but cannot find the binding for the camera. when it is plugged in.
    The error is 'unable to get USB camera binding'.
    A check of Poseidon shows the camera bound to the ptp.class.
    Kodak Easyshare M341
  • »15.11.10 - 15:54
    r-tea
    Posts: 316 from 2005/3/27
    Look at volumes list. AFAIK you don't need this app anymore since MorphOS has ptp.class. Your camera's memory should be accesible as a disk.
  • »16.11.10 - 12:27
    bash64
    I did not see the disk on the desktop.
    I'll keep looking.
  • »16.11.10 - 14:31
    Miky060
    Posts: 694 from 2003/2/24
    If you want to use Ptpdigcam go to Poseidon prefs and "unbind" the camera. It works here. Let us know.
  • »16.11.10 - 18:16
    bash64
    Ok, found it. I thought it would appear on the desktop like all of the other drives do.
    It was under My MorphOS on the desktop.
    So we can say that OS 2.6 mounts PTP cameras but 2.2 did not.
    I kinda liked PtpDigCam.
    I tried to get it to work by unbinding the camera but it still gets errors. "PTP protocol error".
    I'd like to have a choice but no longer a big issue.
  • »16.11.10 - 22:57
