Powermac G4 network device not detected
    Leon
    Posts: 93 from 2003/11/28
    Hello,
    is it possible that the onboard ethernet device of a PowerMac 3.1 (Sawtooth AGP 350mhz) is not detected during MorphOS fresh install? Only loopback adapter is listed.
    [ Edited by Leon on 2010/11/14 15:58 ]
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »14.11.10 - 11:58
    Posts: 12537 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7428&forum=11&start=3
  • »14.11.10 - 12:04
    Simon
    Posts: 809 from 2008/7/6
    In that case it's easily solved with a cheap realtek pci card.
  • »14.11.10 - 14:38
    Yes, that's what has been recommended in the thread I linked to :-)
  • »14.11.10 - 14:53
    Leon
    Thanks for the answers. I will open up the case and see what kind of chip is inside.
    And, should I get a Realtek 8139C or D?
    And how to "disable" the onboard nic if it's not detected?
    Proud owner of:
    Efika
  • »15.11.10 - 18:56
    Simon
    Both C en D should work and should show up in your network preferences. There is nothing or no need to disable anything.
  • »15.11.10 - 19:22
