backing up morphos
    trotter
    Posts: 106 from 2010/1/14
    Hello,
    I wish to back up my working 2.4 version of morphos before i upgrade to 2.6 for this mac mini.
    Do i need to backup the dh1: boot partition as well as the Morphos partition dh2:?
    thanks
    Martin
    Running MorphOS v3.18 on Mac mini 1.5GHz 64meg VRAM,1gig ram.
    Palm T3 pda along with pixel 4a GrapheneOS smartphone. Updated August 2023
  • »08.11.10 - 09:58
    boot_wb
    Posts: 874 from 2007/4/9
    The boot.img on the "boot" partition will be required to boot into MorphOS 2.4 if you want restore your 2.4 setup. However, this "boot" partition contains no configuration information (boot.img is exactly as contained on the original MorphOS iso image).
    If you need to re-install from scratch in the future, you would need the MorphOS 2.4 disk to boot (unless you have some other way of setting up HFS & SFS partitions), which contains this boot.img anyway.
    So "no" you don't need to back the partition up, but "yes" you will need the boot.img file contained therein in order to restore the 2.4 installation (but it can just as easily be taken from the MorphOS 2.4 disk).
    Regards
    Rich
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »08.11.10 - 10:38
    trotter
    ok thanks for that looks like i can leave it since its on the morphos2.4 cd
    Can i use abackup to backup the morphos install like a used to do on classic 68k amiga 4000?
    Or is there some hidden files like windows which requires a special way to backup?
    thanks
    Martin
  • »08.11.10 - 13:13
    Posts: 12498 from 2003/5/22
    No. With MorphOS the user is in full control ;-)
  • »08.11.10 - 14:32
    trotter
    Ahh good next and last Question:
    There is no potential problem backing up to a fat32 partition?
    Martin
  • »08.11.10 - 19:02
    Get27
    Posts: 90 from 2004/8/23
    Not a good idea.
    you will loose file attributes.
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »08.11.10 - 19:12
    If intending to backup to a filesystem that doesn't support AmigaOS/MorphOS peculiarities like protection bits or file comments (like FAT) I'd recommend to put the data into an LHA archive before.
  • »08.11.10 - 19:12
    Posts: 3274 from 2003/3/5
    And I'd recommend using tar instead of lha since it's more reliable and preserves softlinks.
  • »08.11.10 - 19:19
    Simon
    Posts: 809 from 2008/7/6
    how about diavolo ?
    [ Edited by Oepabakkes on 2010/11/8 22:28 ]
  • »08.11.10 - 19:27
    trotter
    Oepabakkes wrote:
    how about diavolo ?
    Is diavolo a ppc native program?
    Any other reason to use it rathr than ABackup?
    I remember trying diabolo on my 4000 but prefered abackup at the time.
    Martin
  • »08.11.10 - 19:55
    https://morph.zone/modules/news/article.php?storyid=1457
  • »08.11.10 - 20:03
    trotter
    Ahh thanks will have to have a look at it along with ABackup.
    It didnt appear on a search of aminet or MorphOS files websites for morphos backup programs
    Martin
  • »08.11.10 - 20:29
    Posts: 2205 from 2003/2/24
    I prefer using backup media which is formatted to Amiga/MorphOS compatible filesystem. It's easy to recover even single files etc from it then and all protection bits etc are preserved for sure. Backup process is fast too.
    I've used SFS formatted USB memory sticks and just recently formatted my 250GB external USB HD to SFS (remember 128GB partition size limit with SFS though!) to collect all my system backups into one place. "copy #? dest: all clone quiet" is good way to make simple backups and if you want to avoid full backuping every time or want to copy softlinks (from SDK for example) correctly, you can use BackUp program or similar software...
    [ Edited by jPV on 2010/11/9 9:40 ]
  • »09.11.10 - 05:34
    trotter
    Get27 wrote:
    Not a good idea.
    But that will not matter if i set diavolo to backup to a hard file?
    Martin
  • »09.11.10 - 09:23
    Simon
    I just wanted to backup with Diavolo. I want to make an "image" from my System (dh1) ... I get a requester that this function is limited to 3.8 TB. My DH1: is 2GB, so not sure why it does that.
    I am now backing it up with the "directory" function... but that's not really what I wanted. I would like to take a complete image of a partition so when something goes wrong I can just put it back after I did boot from the MorphOS iso or something like that.
    [ Edited by Oepabakkes on 2010/11/12 16:34 ]
  • »12.11.10 - 13:32
    matt3
    Posts: 772 from 2004/2/10
    Hi Martin,
    I wouldn't recommend backing up to a hardfile, with the limitations of the native files systems. Perhaps with icefs gets stable or ext2. Or if you can keep the content under a 2 gig hardfile compressed.
    I use and highly recommend backup by onyxsoft, it is found on aminet.net or http://www.onyxsoft.se/. It does a file copy with lots of features and is compatible with Morphos. I have had great luck with it.
    Matt
    [ Edited by matt3 on 2010/11/12 13:39 ]
  • »12.11.10 - 16:36
    Simon
    I used that bach when I had a µA1 ... didn't realize it was MorphOS compatible, it sure is nice backupsoftware.
  • »12.11.10 - 17:15
    trotter
    Thanks for sugggestion but i would like to compress my backup and also exclude some files from compression.
    The exclude in diavolo looks like requires editing a text file unlike what i remmber from abackup on my a4000
    Martin
  • »12.11.10 - 18:34
    matt3
    The author is great to work with, he wrote in compatibility for me and has updated the product fairly often. The executable is still 68k but it does softlinks for MOS.
    Regards,
    Matt
  • »12.11.10 - 19:45
    trotter
    Well since i used ABackup on my 68k a4000 I tried it in morphos
    and it seems to work ok so far with a backup on the a4000 to cd and unarchiving within morphos.
    If anyone knows of any bugs with using 68k ABackup please mention it
    thanks
    Martin
  • »14.11.10 - 15:37
